Введение
As technology advances, it's important to keep up with the latest changes to ensure your home or office network is running as efficiently as possible. The TAE socket was widely used in Germany and other European countries for connecting to DSL modems, but now the RJ45 socket is becoming the new standard. In this guide, we'll walk you through the steps to replace the TAE socket with an RJ45 socket so you can connect directly to your modern DSL modem, like the FritzBox.
Please note that the first outlet in your house typically is a special outlet with a PPA(passive testing termination) that belongs to your ISP and shouldn't be changed.
Выберете то, что вам нужно
Unscrew and remove the cover.
Remove the the connections.
Unscrew the socket from the wall.
Connect La to pin 4 (Blue).
Connect Lb to pin 5 (White-Blue).
Mount the RJ45 socket inside the case and screw on the faceplate.
Have fun surfing the web!
Еще один человек закончил это руководство.
