Введение
Headphone jack worn out? Use this guide to replace the 3.5 mm audio jack and audio jack board as a complete unit.
Выберете то, что вам нужно
Power on your Mac and launch Terminal.
Copy and paste the following command (or type it exactly) into Terminal:
sudo nvram AutoBoot=%00
Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
sudo nvram AutoBoot=%03
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Remove the following eight screws securing the lower case:
Two 1.8 mm P5 Pentalobe screws
Four 2.9 mm P5 Pentalobe screws
Two 6.1 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
Carefully close the MacBook and flip it over once again, so that the Apple logo faces up.
Lifting from the front edge, raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
Инструмент, используемый на этом этапе:Battery Blocker$3.99
As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
Remove the two screws securing the USB-C port cable bracket:
1.1 mm Phillips #00 screw
3.5 mm T5 Torx screw
Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
Use a spudger to flip open the ZIF connector retaining flap for the dual microphone assembly ribbon cable.
Disconnect the microphone assembly ribbon cable by pulling it straight out of its connector.
Remove the two 3.2 mm T5 Torx screws securing the audio jack board to the case.
Еще один человек закончил это руководство.
