Ridgid JobMax R2851 Series B Cord Replacement
Выберете то, что вам нужно
  1. Ridgid JobMax R2851 Series B Cord Replacement, Motor: шаг 1, изображение 1 из 2 Ridgid JobMax R2851 Series B Cord Replacement, Motor: шаг 1, изображение 2 из 2
    • Unplug the device from the wall.
    • Orient the device so that the trigger is facing downwards.
    • Place your thumb and index finger on the two buttons located on the head of the tool.
    • Press the two buttons in and pull the head of the tool off.
  2. Ridgid JobMax R2851 Series B Cord Replacement: шаг 2, изображение 1 из 1
    • Loosen all eight 15mm T10 Torx screws.
    • You do not need to fully remove the screws yet; just loosen them enough that the device shell starts to open.
  3. Ridgid JobMax R2851 Series B Cord Replacement: шаг 3, изображение 1 из 1
    • Orient the device so that the cord end is facing upwards.
    • Take a small cutting tool, and cut down the seam in the back, ensuring that you only cut the sticker.
    • Make a shallow cut to avoid damaging internal hardware.
  4. Ridgid JobMax R2851 Series B Cord Replacement: шаг 4, изображение 1 из 2 Ridgid JobMax R2851 Series B Cord Replacement: шаг 4, изображение 2 из 2
    • Completely remove all eight 15mm T10 Torx screws.
  5. Ridgid JobMax R2851 Series B Cord Replacement: шаг 5, изображение 1 из 3 Ridgid JobMax R2851 Series B Cord Replacement: шаг 5, изображение 2 из 3 Ridgid JobMax R2851 Series B Cord Replacement: шаг 5, изображение 3 из 3
    • Pull the device case off, gripping at the back of the case and rotating it towards the front of the device.
    • Once the device has been separated gently pull on the trigger assembly to remove it from one side of the case.
    • Watch out for the locking mechanism for the head of the device when removing.
  6. Ridgid JobMax R2851 Series B Cord Replacement: шаг 6, изображение 1 из 2 Ridgid JobMax R2851 Series B Cord Replacement: шаг 6, изображение 2 из 2
    • Grip each of the sides of the two green circuit boards and slide them up.
    • Grip each side of the device trigger, and slide it up.
    • You do not need to completely remove these parts. Sliding them upward provides the needed room.
  7. Ridgid JobMax R2851 Series B Cord Replacement: шаг 7, изображение 1 из 2 Ridgid JobMax R2851 Series B Cord Replacement: шаг 7, изображение 2 из 2
    • Grip the motor firmly and pull towards the back of the tool, rotating back forth until the motor is free.
    • When reinstalling the motor, use a spudger to pull back the brushes. This allows the motor to slide into place.
  8. Ridgid JobMax R2851 Series B Cord Replacement, Motor Brushes: шаг 8, изображение 1 из 3 Ridgid JobMax R2851 Series B Cord Replacement, Motor Brushes: шаг 8, изображение 2 из 3 Ridgid JobMax R2851 Series B Cord Replacement, Motor Brushes: шаг 8, изображение 3 из 3
    • Pinch the brush and pry upward away from the center of the part to remove from the device.
    • Take care to not damage the connections on the bottom of the brush.
  9. Ridgid JobMax R2851 Series B Cord Replacement: шаг 9, изображение 1 из 2 Ridgid JobMax R2851 Series B Cord Replacement: шаг 9, изображение 2 из 2
    • Firmly hold the brush in one hand and pull at the base of the wire to disconnect.
  10. Ridgid JobMax R2851 Series B Cord Replacement, Cord: шаг 10, изображение 1 из 1
    • Cut glue holding down the cord.
    • Take care to not damage the casing or cord when cutting the glue.
  11. Ridgid JobMax R2851 Series B Cord Replacement: шаг 11, изображение 1 из 1
    • Lift the cord up and out of the device.
  12. Ridgid JobMax R2851 Series B Cord Replacement: шаг 12, изображение 1 из 1
    • Cut through each of the two wires connecting the cord to the device.
    • Keep in mind that you should cut the wires far enough down to re-wire the device.
    • Strip the wires and solder the replacement cord.
    • Wrap the soldered area in electrical tape before putting the device back together.
Заключение
2 участников успешно повторили данное руководство.
Brent Shepherd
Участник с: 02/12/19
884 Репутация
Автор 5 руководств
Команда
Western Carolina University, Team S1-G5, Virtue Spring 2019 Участник Western Carolina University, Team S1-G5, Virtue Spring 2019
WCU-VIRTUE-S19S1G5
4 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 18
За всё время: 455
