Ring Stick Up Cam Battery Replacement
Выберете то, что вам нужно
  1. Ring Stick Up Cam Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Remove the six 6mm Phillips #00 screws from the back of the device.
    Спросите у FixBot
  2. Ring Stick Up Cam Battery Replacement: шаг 2, изображение 1 из 1
    • Pry off the aluminum plate using a plastic opening tool.
    Спросите у FixBot
  3. Ring Stick Up Cam Battery Replacement: шаг 3, изображение 1 из 1
    • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
    Спросите у FixBot
  4. Ring Stick Up Cam Battery Replacement: шаг 4, изображение 1 из 1
    • Pry off the back cover using a plastic opening tool.
    Спросите у FixBot
  5. Ring Stick Up Cam Battery Replacement: шаг 5, изображение 1 из 1
    • Disconnect the battery power leads using a plastic opening tool.
    Спросите у FixBot
  6. Ring Stick Up Cam Battery Replacement: шаг 6, изображение 1 из 1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
    Спросите у FixBot
Заключение
9 человек успешно провели ремонт по этому руководству.
Nicholos Frey
Участник с: 02/05/19
424 Репутация
1 руководство автора
Команда
UC Davis, Team S18-G3, Lore Winter 2019 Участник UC Davis, Team S18-G3, Lore Winter 2019
UCD-LORE-W19S18G3
3 членов
Автор 8 руководств
12 Комментарии к руководству
Where can I get a replacement battery?
jbains - Ответить Поделиться
Bad news,
After three different calls to the Ring customer service line (just to be certain i was getting the true honest answer each time) i was told that the Ring stickup 1st generation cam - the one in this section is not available and never was. They suggest that this model was never intended yo be dissected as easy as we know it is. the best we can do is to find someone selling one with a damaged camera and removing its battery. That was how i was able to get my 1st gen stickup back in service again.
Dave S - Ответить Поделиться
No reason to try this, no battery replacement? Have searched the Internet, can’t find a replacement!
Robert Byrum - Ответить Поделиться
Why would they not use the same simple replaceable battery system as the ring doorbell2
Peter Lasnick - Ответить Поделиться
Would love to replace the battery, if I could find it online…
Matthew Grow - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 13
За последние 30 дней: 80
За всё время: 13,794
