Введение
In this guide, we'll show you how to replace a faulty power port on the Roku XD 2050X. To complete this guide, you will need to disassemble your device and use a soldering iron to replace the port.
Выберете то, что вам нужно
Turn the device upside down.
Remove the two rubber pads using a plastic spudger.
Insert spudger between upper and lower frame underneath the port access.
Guide spudger around to loosen upper and lower frame to pry frame apart.
Gently remove upper frame.
On the side of the board opposite the ports, find and tilt back the tab securing the board in place.
Lift the motherboard out of the lower frame.
Desolder the 3 contact points.
Remove the power port from the motherboard.
For help with soldering view the iFixit soldering guide.
Еще один человек закончил это руководство.
