Roofing Tile Replacement
Выберете то, что вам нужно
  1. Roofing Tile  Replacement, Roofing Tile: шаг 1, изображение 1 из 1
    • Be cautious when climbing the ladder to the roof. Ensure your ladder is secure before climbing.
    • Ensure the damage has not reached the underlayment.
  2. Roofing Tile  Replacement: шаг 2, изображение 1 из 1
    • Depending on where the damaged tile is on the roof, be sure to prime underlayment before adding new roof tile on top.
  3. Roofing Tile  Replacement: шаг 3, изображение 1 из 1
    • Carefully remove the damaged tile(s) using your hammer and crowbar.
    • Be sure to use an effective safety harness when operating in unsafe conditions.
  4. Roofing Tile  Replacement: шаг 4, изображение 1 из 1
    • Use roof cement to initially attach the tiles to each other and add security to the underlayment.
    • Be sure to wear the proper gear, such as shoes, hats, & breathable clothing.
  5. Roofing Tile  Replacement: шаг 5, изображение 1 из 3 Roofing Tile  Replacement: шаг 5, изображение 2 из 3 Roofing Tile  Replacement: шаг 5, изображение 3 из 3
    • Secure the tile to the cement by pressing down on the tile using the handle of the hammer.
    • Use the handle of the hammer to maneuver into correct position.
    • As seen in the bottom of the picture, using too much cement can leak out from both sides of the tile. Be sure to keep it as hidden underneath the tile as possible.
    • Safety first. Don't forget to wear a harness and be sure to understand handling of cement take.
  6. Roofing Tile  Replacement: шаг 6, изображение 1 из 1
    • Walk carefully on the tiles that are already set into place.
  7. Roofing Tile  Replacement: шаг 7, изображение 1 из 1
    • Use the backside of the hammer to slide up the piece overlapping the broken one, and use a drill to unscrew any screws (which won't be necessary if you're using roof cement). Replace the tile with the new one, and glue in place.
  8. Roofing Tile  Replacement: шаг 8, изображение 1 из 1
    • This is an initial point of view for replacing a single broken tile. You can see the application of roof cement in the crevice of the tile.
Заключение
Number one thing of importance is your safety, my goal is for this guide to give you a general idea of the steps it takes to construct/repair/replace a tile roof.
Еще один человек закончил это руководство.
Jonathan Fuentes
Участник с: 01/13/20
187 Репутация
1 руководство автора
Команда
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 Участник USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020
USFSM-STEWART-S20S1G1
23 членов
Автор 33 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 29
За последние 30 дней: 131
За всё время: 1,550
