Введение
The power adapter port allows power input to the display. The port may need to be replaced if trying a new power adapter cable does not fix display issues.
Выберете то, что вам нужно
Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
Insert the heavy duty spudger in between the monitors back panel and its frame.
Use the heavy duty spudger to pry open the back panel.
Remove the navigation button connector by pulling while holding down its thumb tab.
Remove the screen connector by gripping its sides and gently pulling while wiggling back and forth.
For the ribbon cable, Lift the tab from the side facing the inside of the mother board with your fingernail or a spudger.
Remove the cable by pulling while lifting slightly.
Remove each of the 5mm length screws attaching the motherboard to the body of the monitor using a #1 Phillips head screwdriver.
Using both hands, lift the board off of the monitor body by the motherboards base.
If the power adapter port does not fall out of the board, try tugging on it with your hand.
Еще один человек закончил это руководство.
