Введение
The VGA Port allows for an external source to display an image onto the monitor by using a VGA cable. If the VGA Port is damaged, an image might not display onto the monitor.
Выберете то, что вам нужно
Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
Инструмент, используемый на этом этапе:Heavy-Duty Spudger$4.99
Insert the heavy duty spudger in between the monitors back panel and its frame.
Use the heavy duty spudger to pry open the back panel.
Remove the navigation button connector by pulling while holding down its thumb tab.
Remove the screen connector by gripping its sides and gently pulling while wiggling back and forth.
For the ribbon cable, Lift the tab from the side facing the inside of the mother board with your fingernail or a spudger.
Remove the cable by pulling while lifting slightly.
Remove each of the 5mm length screws attaching the motherboard to the body of the monitor using a #1 Phillips head screwdriver.
Using both hands, lift the board off of the monitor body by the motherboards base.
Desolder the four regions in the area indicated on the back side of the motherboard using a soldering iron and some desoldering wick.
