Samsung ATIV Book 4 Mouse Pad Replacement
Выберете то, что вам нужно
  1. Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: шаг 1, изображение 1 из 3 Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: шаг 1, изображение 2 из 3 Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: шаг 1, изображение 3 из 3
    • Place the computer upside down.
    • Remove the two rubber pads, by prying up on them.
    • There may be adhesive holding them down.
    • Remove the seven 6.5mm screws on exterior of computer.
    • Remove panel by sliding it down and lifting it away from the computer.
  2. Samsung ATIV Book 4 Mouse Pad Replacement: шаг 2, изображение 1 из 1
    • Remove the four 4.4mm screws that are underneath the panel.
    • Remove the two 6.5mm screws that were underneath the rubber pads.
  3. Samsung ATIV Book 4 Mouse Pad Replacement: шаг 3, изображение 1 из 2 Samsung ATIV Book 4 Mouse Pad Replacement: шаг 3, изображение 2 из 2
    • Using plastic opening tool, pry plastic panel away from computer.
    • Start prying at one point and work your way around the entire computer until panel is free come computer.
    • Remove the panel from computer once all tabs are broke free.
  4. Samsung ATIV Book 4 Mouse Pad Replacement: шаг 4, изображение 1 из 2 Samsung ATIV Book 4 Mouse Pad Replacement: шаг 4, изображение 2 из 2
    • Pull this tab outwards, as shown, to release the wire harness.
    • With the tab now pulled out, pull lightly on the blue tape, to remove the harness.
    • Pull on the blue tape to remove wire harness.
    • This harness may require a little more force to remove, but will slide right out.
    • Remove the two 3.5mm screws and remove the defective hardware.
    • This step may be easier if the battery is taken out. Follow the battery replacement guide to do so.
Заключение
Daniel
Участник с: 03/19/15
342 Репутация
Автор 3 руководств
Команда
Michigan Tech, Team 1-7, Lauer Spring 2015 Участник Michigan Tech, Team 1-7, Lauer Spring 2015
MTU-LAUER-S15S1G7
2 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 1,094
