Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If your Samsung Captivate is not connecting to the network, one problem could be a faulty antenna cable. Replacing this part is very simple and can be accomplished by anyone.
Выберете то, что вам нужно
Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
Lift up the back cover.
Insert the spudger underneath the bottom section of the phone.
Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
Starting at a bottom corner, use the spudger to separate the rear case from the front display.
Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
Pry up the other end of the cable from the connector on the antenna array.
7 участников успешно повторили данное руководство.
2 Комментариев
Quick question, is this the antenna for wifi or cellular network?
This is actually just the cable that connects the motherboard to the antenna array. I believe the antenna array that it connects to is for WiFi though.
