Samsung Epix Keyboard Replacement
Выберете то, что вам нужно
  1. Samsung Epix Keyboard Replacement, Battery: шаг 1, изображение 1 из 1
    • Just below the phone's camera, press the button and hold it
    • While the button is held down, slide the back panel off to remove it completely.
    Спросите у FixBot
    Добавить комментарий
  2. Samsung Epix Keyboard Replacement: шаг 2, изображение 1 из 1
    • Grasp the bottom corners of the battery with two fingers and gently lift.
    • Gently lift the battery and remove it from the phone.
    Спросите у FixBot
  3. Samsung Epix Keyboard Replacement, Keyboard: шаг 3, изображение 1 из 1
    • Using a plastic prying tool, remove the screw cover in the top left corner of the phone by lifting it up.
    • Be gentle
    Спросите у FixBot
  4. Samsung Epix Keyboard Replacement: шаг 4, изображение 1 из 1
    • Use the Phillips #00 screwdriver to remove the six screws on the back of the phone.
    • Three of the screws are evenly spaced on the left and right side on the back of the phone.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
    Спросите у FixBot
  5. Samsung Epix Keyboard Replacement: шаг 5, изображение 1 из 2 Samsung Epix Keyboard Replacement: шаг 5, изображение 2 из 2
    • Insert the prying tool into the seam on the side of the phone and turn it slightly. Do this for each of the eight clips to unhook them
    • There are three clips on each side and two at the bottom of the phone.
    Спросите у FixBot
  6. Samsung Epix Keyboard Replacement: шаг 6, изображение 1 из 1
    • Once all eight of the clips have been unhooked, lift the back panel gently off of the phone.
    • Be careful and do not attempt to remove the front panel. It is still connected to the phone's chassis by a ribbon cable which is located in the bottom right side of the motherboard.
    Спросите у FixBot
  7. Samsung Epix Keyboard Replacement: шаг 7, изображение 1 из 1
    • Using the plastic prying tool, unlatch the ribbon cable located in the lower right corner of the motherboard.
    • Carefully disconnect the ribbon cable.
    Спросите у FixBot
  8. Samsung Epix Keyboard Replacement: шаг 8, изображение 1 из 1
    • Gently lift and remove the front faceplate
    • Exercise caution
    Спросите у FixBot
  9. Samsung Epix Keyboard Replacement: шаг 9, изображение 1 из 1
    • Grasp the rubber keyboard in the corner with your fingers and lift to remove it.
    • Lift it and gently take it out the frame to remove it.
    Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Chris
Участник с: 04/20/11
32 Репутация
1 руководство автора
Команда
Cal Poly, Team 15-15, Regan Spring 2011 Участник Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
5 членов
Автор 5 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 47
За всё время: 2,023
