Введение
Use this guide to remove or replace a damaged back cover on your Galaxy A10.
Выберете то, что вам нужно
Insert a SIM card eject tool, a SIM eject bit or a straightened paper clip into the hole on the SIM tray located at the left side of the phone.
Press firmly to eject the tray.
Insert an opening pick between the screen and the back cover on the bottom of the phone where the charging port is located.
Slide the opening pick along the left edge to the top left corner of the phone, to release the clips.
Slide the opening pick from the top left corner to the top right corner to release the plastic clips.
Slide the opening pick from the top left corner to the bottom right corner to release the remaining clips.
20 участников успешно повторили данное руководство.
