Samsung Galaxy Book Pro 15" Secondary SSD Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Remove the rubber feet: шаг 1, изображение 1 из 3 Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Remove the rubber feet: шаг 1, изображение 2 из 3 Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Remove the rubber feet: шаг 1, изображение 3 из 3
    • Before you begin, power down your laptop and unplug it.
    • There are two kinds of rubber feet along the top and bottom of the rear case. Keep track of their position as you remove them.
    • Insert an opening pick between the rubber foot and the rear case.
    • Pry up with the opening pick to release the clips securing the foot.
    • Remove the foot.
    • Repeat this procedure for the three remaining feet.
    • During reassembly, press the feet into their correct slot to reinsert them. Mismatched feet won't fit correctly.
  2. Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Unfasten the rear case: шаг 2, изображение 1 из 2 Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Unfasten the rear case: шаг 2, изображение 2 из 2
    • Use a Phillips screwdriver to remove the four 4.5 mm-long screws securing the rear case.
  3. Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Insert an opening pick: шаг 3, изображение 1 из 3 Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Insert an opening pick: шаг 3, изображение 2 из 3 Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Insert an opening pick: шаг 3, изображение 3 из 3
    • Apply a suction cup to the rear case, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear case and the frame.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Release the clips: шаг 4, изображение 1 из 3 Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Release the clips: шаг 4, изображение 2 из 3 Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Release the clips: шаг 4, изображение 3 из 3
    • Slide the pick along the bottom edge of the rear case to release its plastic clips.
    • Repeat this process for the left and right edges, but stop before reaching the top edge.
  5. Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Remove the rear case: шаг 5, изображение 1 из 3 Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Remove the rear case: шаг 5, изображение 2 из 3 Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Remove the rear case: шаг 5, изображение 3 из 3
    • The top edge of the rear case is lightly adhered to the frame.
    • Pull the top of the rear case away from the frame to separate the adhesive and release the remaining clips.
    • If you're having trouble separating the adhesive, use an iOpener, hair dryer, or heat gun to soften it.
    • Remove the rear case.
    • During reassembly, perform the following:
    • If you're using a using a genuine Samsung replacement rear case, be sure to peel off any adhesive liners from the rear case before securing the top edge's clips.
    • If you're reusing your rear case, you can use some pre-cut adhesive to re-adhere the top edge if your existing adhesive is no longer sticky.
    • This is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down completely before you continue working.
  6. Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Disconnect the battery: шаг 6, изображение 1 из 2 Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Disconnect the battery: шаг 6, изображение 2 из 2
    • Insert a spudger between the frame and the bottom of the battery cable connector.
    • Pry up and disconnect the battery cable connector.
  7. Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Unfasten the SSD: шаг 7, изображение 1 из 2 Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Unfasten the SSD: шаг 7, изображение 2 из 2
    • If your Galaxy Book doesn't have a 2280 SSD, skip the next two steps.
    • Use a Phillips screwdriver to remove the 3.5 mm-long screw securing the SSD.
  8. Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Remove the SSD: шаг 8, изображение 1 из 3 Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Remove the SSD: шаг 8, изображение 2 из 3 Samsung Galaxy Book Pro 15" Secondary SSD Replacement, Remove the SSD: шаг 8, изображение 3 из 3
    • Lift the free end of the SSD up slightly and pull the SSD straight out of its socket on the motherboard.
Заключение
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
2 человек успешно провели ремонт по этому руководству.
Alex Diaz-Kokaisl
Участник с: 01/16/22
161 942 Репутация
Автор 769 руководств
Команду
iFixit Участник iFixit
Staff
118 членов
Автор 19 410 руководств
2 Комментариев
It’s possible to add a second SSD for the book 5 360 pro?
Rubén Rodríguez Cueto - Ответить
For the Samsung Galaxy Book Pro 360 15", you can add a second SSD! Just make sure it's the same dimensions (M.2 2280) as the first one.
Alex Diaz-Kokaisl -
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 5
За последние 7 дней: 24
За последние 30 дней: 84
За всё время: 2,571
