Samsung Galaxy Book Pro 15" Touchpad Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the rubber feet: шаг 1, изображение 1 из 3 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the rubber feet: шаг 1, изображение 2 из 3 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the rubber feet: шаг 1, изображение 3 из 3
    • Before you begin, power down your laptop and unplug it.
    • There are two kinds of rubber feet along the top and bottom of the rear case. Keep track of their position as you remove them.
    • Insert an opening pick between the rubber foot and the rear case.
    • Pry up with the opening pick to release the clips securing the foot.
    • Remove the foot.
    • Repeat this procedure for the three remaining feet.
    • During reassembly, press the feet into their correct slot to reinsert them. Mismatched feet won't fit correctly.
  2. Samsung Galaxy Book Pro 15" Touchpad Replacement, Unfasten the rear case: шаг 2, изображение 1 из 2 Samsung Galaxy Book Pro 15" Touchpad Replacement, Unfasten the rear case: шаг 2, изображение 2 из 2
    • Use a Phillips screwdriver to remove the four 4.5 mm-long screws securing the rear case.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #3313.
  3. Samsung Galaxy Book Pro 15" Touchpad Replacement, Insert an opening pick: шаг 3, изображение 1 из 3 Samsung Galaxy Book Pro 15" Touchpad Replacement, Insert an opening pick: шаг 3, изображение 2 из 3 Samsung Galaxy Book Pro 15" Touchpad Replacement, Insert an opening pick: шаг 3, изображение 3 из 3
    • Apply a suction cup to the rear case, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear case and the frame.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy Book Pro 15" Touchpad Replacement, Release the clips: шаг 4, изображение 1 из 3 Samsung Galaxy Book Pro 15" Touchpad Replacement, Release the clips: шаг 4, изображение 2 из 3 Samsung Galaxy Book Pro 15" Touchpad Replacement, Release the clips: шаг 4, изображение 3 из 3
    • Slide the pick along the bottom edge of the rear case to release its plastic clips.
    • Repeat this process for the left and right edges, but stop before reaching the top edge.
  5. Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the rear case: шаг 5, изображение 1 из 3 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the rear case: шаг 5, изображение 2 из 3 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the rear case: шаг 5, изображение 3 из 3
    • The top edge of the rear case is lightly adhered to the frame.
    • Pull the top of the rear case away from the frame to separate the adhesive and release the remaining clips.
    • If you're having trouble separating the adhesive, use an iOpener, hair dryer, or heat gun to soften it.
    • Remove the rear case.
    • During reassembly, perform the following:
    • If you're using a using a genuine Samsung replacement rear case, be sure to peel off any adhesive liners from the rear case before securing the top edge's clips.
    • If you're reusing your rear case, you can use some pre-cut adhesive to re-adhere the top edge if your existing adhesive is no longer sticky.
    • This is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down completely before you continue working.
  6. Samsung Galaxy Book Pro 15" Touchpad Replacement, Disconnect the battery: шаг 6, изображение 1 из 2 Samsung Galaxy Book Pro 15" Touchpad Replacement, Disconnect the battery: шаг 6, изображение 2 из 2
    • Insert a spudger between the frame and the bottom of the battery cable connector.
    • Pry up and disconnect the battery cable connector.
  7. Samsung Galaxy Book Pro 15" Touchpad Replacement, Unfasten the battery: шаг 7, изображение 1 из 2 Samsung Galaxy Book Pro 15" Touchpad Replacement, Unfasten the battery: шаг 7, изображение 2 из 2
    • Use a Phillips screwdriver to remove the four 4.5 mm-long screws securing the battery.
    • Take care not to puncture the battery with your screwdriver—a punctured battery may leak dangerous chemicals or cause a fire.
  8. Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the battery: шаг 8, изображение 1 из 3 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the battery: шаг 8, изображение 2 из 3 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the battery: шаг 8, изображение 3 из 3
    • Lift the battery straight out of the frame and remove it.
  9. Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the tape: шаг 9, изображение 1 из 2 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the tape: шаг 9, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Купить
    • Use tweezers, or your fingers, to peel back and remove the yellow tape covering the touchpad's cable connector.
  10. Samsung Galaxy Book Pro 15" Touchpad Replacement, Disconnect the touchpad: шаг 10, изображение 1 из 2 Samsung Galaxy Book Pro 15" Touchpad Replacement, Disconnect the touchpad: шаг 10, изображение 2 из 2
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the touchpad cable.
  11. Samsung Galaxy Book Pro 15" Touchpad Replacement: шаг 11, изображение 1 из 2 Samsung Galaxy Book Pro 15" Touchpad Replacement: шаг 11, изображение 2 из 2
    • Disconnect the touchpad cable by sliding it out from its socket on the touchpad.
  12. Samsung Galaxy Book Pro 15" Touchpad Replacement, Reposition the cable: шаг 12, изображение 1 из 2 Samsung Galaxy Book Pro 15" Touchpad Replacement, Reposition the cable: шаг 12, изображение 2 из 2
    • The touchpad cable is lightly adhered to the touchpad.
    • Use your fingers, or tweezers, to peel the touchpad cable away from the touchpad and separate its adhesive.
  13. Samsung Galaxy Book Pro 15" Touchpad Replacement, Unfasten the touchpad: шаг 13, изображение 1 из 2 Samsung Galaxy Book Pro 15" Touchpad Replacement, Unfasten the touchpad: шаг 13, изображение 2 из 2
    • Use a Phillips #00 screwdriver to remove the five 1.7 mm screws securing the touchpad.
  14. Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the touchpad: шаг 14, изображение 1 из 3 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the touchpad: шаг 14, изображение 2 из 3 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the touchpad: шаг 14, изображение 3 из 3
    • Swing the display open slightly, but keep the laptop upside-down.
    • Tilt the touchpad upwards and away from the frame.
    • Pull the touchpad towards the top of the laptop to separate it from its recess in the frame.
    • Remove the touchpad.
  15. Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the tape: шаг 15, изображение 1 из 2 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the tape: шаг 15, изображение 2 из 2
    • Use tweezers to peel off and remove the conductive tape on the touchpad.
    • Set the tape aside. You'll reuse it during reassembly.
Заключение
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
Alex Diaz-Kokaisl
Участник с: 01/16/22
124 921 Репутация
Автор 582 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 392 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 37
За всё время: 721
