Введение
Use this guide to replace the screen on your Galaxy Book Pro 360 15" laptop with a genuine Samsung part.
Before you begin, refer to the Samsung PC Repair Guide for safety information.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of a thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Выберете то, что вам нужно
Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
Insert an opening pick between the rear case and the rubber foot.
Pry up with the pick and dislodge the foot from the rear case.
Use tweezers or your fingers to remove the rubber foot.
Repeat this process on the remaining rubber feet.
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Use a Phillips screwdriver to remove the four 4.5 mm screws securing the rear case.
Apply a suction handle to the middle of the rear case's bottom edge, as close to the edge as possible.
Pull up on the handle with a strong, steady force to create a small gap between the rear case and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick along the bottom edge to release the clips securing the rear case.
Continue sliding the pick along the perimeter of the laptop until all the clips securing the rear case have been released.
Lift the rear case up and away from the laptop and remove it.
Use tweezers or your fingers to peel up and remove the tape covering the battery connector.
Insert the flat end of a spudger under the battery cables, as close to the connector as possible.
Gently pry up and disconnect the battery connector from its socket.
Use the flat end of a spudger to pry up the locking flap on the right display cable's ZIF connector.
Use tweezers or your fingers to grip the display cable's pull tab and gently pull the cable out of its socket on the motherboard.
Slowly pull the right display cable out of its recess.
Repeat the disconnection and removal procedure on the left display cable.
Open the laptop until it's completely flat and lay it down with the display and keyboard facing down.
Use a Phillips screwdriver to remove the three 3.6 mm screws securing the right screen hinge.
Use a Phillips screwdriver to remove the three 3.6 mm screws securing the left screen hinge.
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
3 участников успешно повторили данное руководство.
3 Комментариев
This is the display assembly. How do you replace the screen?
Rob -
