Введение
This guide will walk you through the process of replacing a not working back camera in a Samsung Galaxy J3V.
Выберете то, что вам нужно
Place your thumb on the top left corner and pry the tab open and lift off the back cover.
Use a small suction cup to pull the screen up. Then slip a small plastic opening tool under the screen to pry it upwards.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use tweezers to flip tab of the front camera to remove it.
Remove connector tab with spudger then carefully remove headphone jack with tweezers.
After removing the motherboard, locate and flip tab holding the rear camera's connector.
Carefully use the tweezer to remove the connector and the camera.
Еще один человек закончил это руководство.
1 Комментарий к руководству
Your &&^&^$^ trash and did not help me at all.
