Samsung Galaxy Note 4 Display Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Note 4 Display Replacement, Rear Case: шаг 1, изображение 1 из 2 Samsung Galaxy Note 4 Display Replacement, Rear Case: шаг 1, изображение 2 из 2
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy Note 4 Display Replacement, Battery: шаг 2, изображение 1 из 1
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery.
  3. Samsung Galaxy Note 4 Display Replacement, Display: шаг 3, изображение 1 из 1
    • Prepare an iOpener and heat the display along the left edge for about two minutes.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  4. Samsung Galaxy Note 4 Display Replacement: шаг 4, изображение 1 из 3 Samsung Galaxy Note 4 Display Replacement: шаг 4, изображение 2 из 3 Samsung Galaxy Note 4 Display Replacement: шаг 4, изображение 3 из 3
    • Once the screen is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can.
    • If your display is badly cracked, the suction cup may not stick. Try lifting the display with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Lift on the suction cup, and insert an opening pick under the display assembly.
  5. Samsung Galaxy Note 4 Display Replacement: шаг 5, изображение 1 из 3 Samsung Galaxy Note 4 Display Replacement: шаг 5, изображение 2 из 3 Samsung Galaxy Note 4 Display Replacement: шаг 5, изображение 3 из 3
    • Slide the opening pick along the left edge of the display to separate the adhesive underneath.
    • The display and digitizer cables are located near the top of the display and may interfere with your pick if you pry too deeply.
    • If cutting becomes difficult, reheat and reapply the iOpener.
    • Leave the pick in place to prevent the adhesive from re-adhering and grab a second pick as you proceed to the next step.
  6. Samsung Galaxy Note 4 Display Replacement: шаг 6, изображение 1 из 3 Samsung Galaxy Note 4 Display Replacement: шаг 6, изображение 2 из 3 Samsung Galaxy Note 4 Display Replacement: шаг 6, изображение 3 из 3
    • Apply a heated iOpener to the bottom of the phone.
    • Slide an opening pick along the bottom of the phone.
    • Only insert the pick about 0.25 inches (6 mm) to avoid damage to the home button or either of the delicate capacitive buttons at the bottom of the phone.
  7. Samsung Galaxy Note 4 Display Replacement: шаг 7, изображение 1 из 2 Samsung Galaxy Note 4 Display Replacement: шаг 7, изображение 2 из 2
    • Insert an opening pick 0.5 inches (12.5mm) into the left side of the bottom edge of the phone.
    • Push the pick in slowly and gently to avoid tearing the delicate capacitive button ribbon cable underneath the display. Reapply an iOpener if it's difficult to insert the pick.
    • Once the pick has cut through the adhesive, leave it in place to prevent the adhesive from resealing.
  8. Samsung Galaxy Note 4 Display Replacement: шаг 8, изображение 1 из 2 Samsung Galaxy Note 4 Display Replacement: шаг 8, изображение 2 из 2
    • Insert an opening pick 0.5 inches (12.5mm) into the right side of the bottom edge of the phone.
  9. Samsung Galaxy Note 4 Display Replacement: шаг 9, изображение 1 из 2 Samsung Galaxy Note 4 Display Replacement: шаг 9, изображение 2 из 2
    • Apply a heated iOpener to the right edge of the phone.
    • Slide the opening pick along the right edge of the display to separate the adhesive underneath.
    • Don't insert the pick more than 1 inch (25 mm) underneath the display to avoid damaging the home button cable.
  10. Samsung Galaxy Note 4 Display Replacement: шаг 10, изображение 1 из 2 Samsung Galaxy Note 4 Display Replacement: шаг 10, изображение 2 из 2
    • Gently slide an opening pick under the top edge of the display to separate the adhesive underneath.
    • Only insert the pick about 0.25 inches (6 mm) under the display.
    • Don't pry too aggressively or you may damage the front-facing sensors and speaker assembly. You can come back to finish separating this section after the rest of the display is loose.
  11. Samsung Galaxy Note 4 Display Replacement: шаг 11, изображение 1 из 2 Samsung Galaxy Note 4 Display Replacement: шаг 11, изображение 2 из 2
    • Use your picks as needed to finish separating the adhesive beneath all areas of the display.
    • Pry the bottom part of the display away from the phone until they are fully separated.
  12. Samsung Galaxy Note 4 Display Replacement: шаг 12, изображение 1 из 2 Samsung Galaxy Note 4 Display Replacement: шаг 12, изображение 2 из 2
    • Gently lift the display so you an easily access the display and digitizer connectors.
    • You may want to support the display with something, such as the box the phone came in, while you disconnect the display and digitizer cables.
  13. Samsung Galaxy Note 4 Display Replacement: шаг 13, изображение 1 из 2 Samsung Galaxy Note 4 Display Replacement: шаг 13, изображение 2 из 2
    • Use the flat end of a spudger to pry the display cable connector straight up and out of its socket.
  14. Samsung Galaxy Note 4 Display Replacement: шаг 14, изображение 1 из 2 Samsung Galaxy Note 4 Display Replacement: шаг 14, изображение 2 из 2
    • Use the flat end of a spudger to pry the digitizer cable connector straight up and out of its socket.
  15. Samsung Galaxy Note 4 Display Replacement: шаг 15, изображение 1 из 3 Samsung Galaxy Note 4 Display Replacement: шаг 15, изображение 2 из 3 Samsung Galaxy Note 4 Display Replacement: шаг 15, изображение 3 из 3
    • Remove the display.
    • Before installing a new display, it's very important to remove all traces of the old adhesive from the frame, while taking special care to remove any small glass fragments.
    • After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter. Swipe in one direction only, not back and forth.
    • If the frame is bent, or if any glue or glass remnants are left behind, the new display will not mount correctly and may be damaged.
    • The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
Заключение
25 человек успешно провели ремонт по этому руководству.
Adam O'Camb
Участник с: 04/11/15
219 282 Репутация
Автор 416 руководств
1 Комментарий к руководству
Merci, en prenant bien le temps et avec les outils ça la fait. Une bouillotte a la place du Iopenit mais le pack Pro Teck Toolkit est suffisant pour cette ouvrage. c'est clairement pas une course, j'étais pas loin des 2 heures mais j'ai récupéré un bon écran sur un tel hs pour remplacer l'écran cassé de mon vieux Note 4. il a reprit vie comme en 2019...J'ai encore du mal a le croire. Merci beaucoup, je n'aurai pas osé me lancer sans ce tuto. ps:la parti recollage manque de détails et de photos selon moi
cyp cabs - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 27
За последние 30 дней: 91
За всё время: 15,826
