Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Follow this guide to replace the display or screen adhesives for the Galaxy S8+. This procedure is meant to be used in conjunction with the Galaxy S8+ screen replacement guide.
Выберете то, что вам нужно
Remove all traces of adhesive and debris from the phone's frame. Clean the adhesion surface with high concentration isopropyl alcohol (over 90%) and wipe it clean with a lint-free cloth.
Lay the adhesive strips out to get an idea of where they go.
Peel off the clear plastic backing from the large pre-cut adhesive strip, exposing one side of adhesive.
Carefully line up a long edge of the adhesive with the edge of the phone frame.
Set the adhesive down lightly on the frame.
If it is not properly aligned, carefully peel the adhesive back up.
Once the adhesive is aligned, use your fingers to press the adhesive onto the frame.
Peel one of the end adhesive strips from the clear plastic backing.
Hold the strip by the two green end tabs and line the adhesive strip with the phone frame.
Lay the adhesive down lightly on the phone. Make sure that all cutouts are properly aligned.
Once aligned, use your fingers to press the adhesive into place.
Repeat the procedure for the remaining adhesive strip.
Continue reassembling your device until you are ready to attach the screen.
Peel and remove the green plastic liner from all adhesive strips to expose the screen-facing adhesive.
Align and set the phone screen on top of the adhesive.
Use your fingers to squeeze around the perimeter of the phone to set the adhesive.
Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
Follow this link to return to the Galaxy S8+ screen replacement guide.
8 участников успешно повторили данное руководство.
