Введение
If there is no sound coming from your speakers, this guide will instruct you on how to replace the speakers.
Выберете то, что вам нужно
Have the front of the device facing you.
Begin near one of the curved edges of the device (see photo two for visual example).
Place a plastic opening tool between the front and back panels.
Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
Lift the back panel off of the device.
Remove the adhesive film and flip up the retaining flap on the ZIF battery connector.
Slide the orange battery ribbon cable out of the ZIF connector.
Remove the adhesive film, lift the retaining tab and withdraw the white speaker ribbon.
Using a Phillips #000 screwdriver, remove the ten 4 mm screws around the battery.
Slide a plastic opening tool under the bottom of the battery close to the speakers and lift up.
Place the plastic opening tool on the edge of the speaker.
Lodge the plastic opening tool under each speaker and lift them up and out of the device.
2 участников успешно повторили данное руководство.
2 Комментариев
Where is a good place to buy the replacement speaker?
Where is a good place to buy a speaker?
