Samsung Galaxy Tab S2 9.7 AT&T Headphone Jack Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Tab S2 9.7 AT&T Headphone Jack Replacement, Screen: шаг 1, изображение 1 из 2 Samsung Galaxy Tab S2 9.7 AT&T Headphone Jack Replacement, Screen: шаг 1, изображение 2 из 2
    • Apply the heat gun around the edges of the tablet to melt the adhesive glue.
    • Do not allow the gun to remain still for more than two seconds, so that you do not melt the plastic around the screen.
    • If you do not have access to a heat gun, you may also use an iOpener or a hair dryer. Refer to the iOpener guide for extra help.
  2. Samsung Galaxy Tab S2 9.7 AT&T Headphone Jack Replacement: шаг 2, изображение 1 из 2 Samsung Galaxy Tab S2 9.7 AT&T Headphone Jack Replacement: шаг 2, изображение 2 из 2
    • Apply the suction to the bottom or top right corner.
    • Use the plastic opening tool at several points around the screen while the suction is being applied to pop the screen out.
  3. Samsung Galaxy Tab S2 9.7 AT&T Headphone Jack Replacement: шаг 3, изображение 1 из 1
    • Once the screen is detached, open the tablet like a book.
    • Gently open the tablet, and do not pull the pieces apart since you can risk damaging the orange ribbon cable.
  4. Samsung Galaxy Tab S2 9.7 AT&T Headphone Jack Replacement: шаг 4, изображение 1 из 1
    • Using the precision tweezers, remove the silver tape that is holding the orange ribbon cable connecting the two pieces.
  5. Samsung Galaxy Tab S2 9.7 AT&T Headphone Jack Replacement: шаг 5, изображение 1 из 1
    • Using the precision tweezers, remove the small press-fit connector from the body of the tablet.
  6. Samsung Galaxy Tab S2 9.7 AT&T Headphone Jack Replacement, Screws: шаг 6, изображение 1 из 2 Samsung Galaxy Tab S2 9.7 AT&T Headphone Jack Replacement, Screws: шаг 6, изображение 2 из 2
    • Using the Philips #000 screwdriver, remove the seventeen 2.74 mm screws around the edges.
    • Remove the two 2.74 mm black screws in the middle of the tablet with the Philips #000 screwdriver.
    • Put the screws on a magnetic project mat or in a container so that you do not lose them.
  7. Samsung Galaxy Tab S2 9.7 AT&T Headphone Jack Replacement: шаг 7, изображение 1 из 3 Samsung Galaxy Tab S2 9.7 AT&T Headphone Jack Replacement: шаг 7, изображение 2 из 3 Samsung Galaxy Tab S2 9.7 AT&T Headphone Jack Replacement: шаг 7, изображение 3 из 3
    • Take the plastic opening tool around the tablet to remove the motherboard from the device.
  8. Samsung Galaxy Tab S2 9.7 AT&T Headphone Jack Replacement, Headphone Jack: шаг 8, изображение 1 из 2 Samsung Galaxy Tab S2 9.7 AT&T Headphone Jack Replacement, Headphone Jack: шаг 8, изображение 2 из 2
    • Locate the headphone jack towards the bottom right-hand side.
    • Using the plastic opening tool, lift up the press-fit connector.
  9. Samsung Galaxy Tab S2 9.7 AT&T Headphone Jack Replacement: шаг 9, изображение 1 из 1
    • Using the Phillips #000 Screwdriver, remove the 2.74 mm black screw next to the headphone jack.
  10. Samsung Galaxy Tab S2 9.7 AT&T Headphone Jack Replacement: шаг 10, изображение 1 из 1
    • Using the precision tweezers, remove the headphone jack.
Заключение
2 участников успешно повторили данное руководство.
Joy Harris
Участник с: 02/15/17
814 Репутация
Автор 7 руководств
Команда
USF Tampa, Team S3-G4, Sullivan Spring 2017 Участник USF Tampa, Team S3-G4, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G4
3 членов
Автор 14 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 765
