Введение
A damaged screen makes viewing anything on the tablet difficult. Removing the screen may require a heat gun or an iOpener. Check out this iOpener guide for instructions on how to use it.
Выберете то, что вам нужно
Apply the heat gun around the edges of the tablet to melt the adhesive glue.
Apply the suction to the bottom or top right corner.
Use the plastic opening tool at several points around the screen while the suction is being applied to pop the screen out.
Using the precision tweezers, remove the silver tape that is holding the orange ribbon cable connecting the two pieces.
Using the precision tweezers, remove the small press-fit connector from the body of the tablet.
2 участников успешно повторили данное руководство.
3 Комментариев
Hí, my Tab S2 has been to a Samsung Service Center for screen replacement, after which they had to open it again, they were not very skilled professionals, and now my screen is not attached to the frame, it is popping out on all sides. Is there a way to glue in the display? Is there a replacement adhesive available?
Hi, my Samsung Tab S2 9.7 has been at a Samsung shop for a new LCD, and they had to reopen it again after the new display has been installed. They were not very skilled professionals. Now my display is not attached to the frame properly and is lifting 1-2mm out of the frame, on all sides, and feels loose. Is there a replacement adhesive to attach the display properly? Or is there some other way to glue in the display? Thanks.
Thanks For this update
I Got AT&T Internet From AT&T Internet Deals
