Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement, Screen: шаг 1, изображение 1 из 1
    • Heat the iOpeners in a microwave for 1-2 minutes.
    • The iOpeners will be hot. Use caution and hold the tabs on the ends.
    • Place heated iOpeners on screen edges to heat the adhesive.
    • For more detailed instructions on how to use the iOpeners, please refer to the iOpener Instructions.
  2. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 2, изображение 1 из 1
    • Separate the screen assembly from the back by wedging the picks between the two components.
    • Slide the picks along the edge and leave them holding the device open all around the edges.
  3. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 3, изображение 1 из 1
    • Place suctioning device near the corner of the screen and gently lift up to create a gap between the front panel assembly and the back.
    • Insert the picks to hold the two components apart once a gap is created.
  4. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 4, изображение 1 из 1
    • Once all edges have been disconnected, carefully lift the screen off by pulling one side up.
    • Be careful not to cut yourself. Any broken glass from the screen will be sharp.
  5. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 5, изображение 1 из 1
    • Using the tweezers, gently peel up on the silver tape covering the connector.
  6. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 6, изображение 1 из 1
    • Use the plastic opening tool to get under the connector piece. This will allow you to remove the front panel assembly from the rest of the device.
  7. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 7, изображение 1 из 1
    • Detach the connecter from the inside of the device.
    • Lift the screen to separate the front panel assembly from the rest of the device.
  8. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement, Central Panel: шаг 8, изображение 1 из 2 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement, Central Panel: шаг 8, изображение 2 из 2
    • Remove the 17 silver 3.0 mm Phillips head screws located around the edge of the device using the screwdriver.
    • For additional information on how to remove screws, please refer to Screwdriver Best Practices.
  9. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 9, изображение 1 из 2 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 9, изображение 2 из 2
    • Remove the 2 centrally-located black 3.0 mm Phillips head screws using the screwdriver.
  10. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 10, изображение 1 из 2 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 10, изображение 2 из 2
    • Use the plastic opening tools to gently separate the middle panel from the rest of the device.
    • Move the tool around under the edges until you can remove the panel by hand.
    • Popping/cracking noises are completely normal. These are the sounds of the panel separating from the rest of the device.
  11. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 11, изображение 1 из 3 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 11, изображение 2 из 3 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 11, изображение 3 из 3
    • Lift up the central panel starting from one corner to separate it from the rest of the device.
    • Pull towards the top of the device as you lift out to ensure that the charging port connection is not damaged.
  12. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement, Motherboard: шаг 12, изображение 1 из 3 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement, Motherboard: шаг 12, изображение 2 из 3 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement, Motherboard: шаг 12, изображение 3 из 3
    • Using the screwdriver, remove the 4 black 3.0 mm Phillips head screws located on the upper and lower motherboard.
  13. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 13, изображение 1 из 1
    • Using the plastic opening tools unlock the 11 connectors that must be undone before the motherboard can be removed.
  14. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 14, изображение 1 из 3 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 14, изображение 2 из 3 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 14, изображение 3 из 3
    • Using the plastic opening tool, continue disconnecting cables on upper motherboard.
  15. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 15, изображение 1 из 3 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 15, изображение 2 из 3 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 15, изображение 3 из 3
    • Continue disconnecting along the left side of the device.
  16. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 16, изображение 1 из 3 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 16, изображение 2 из 3 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 16, изображение 3 из 3
    • Continue removing cables on the lower motherboard.
  17. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 17, изображение 1 из 1
    • Using tweezers, remove the green plastic film to reach the last cable.
  18. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 18, изображение 1 из 3 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 18, изображение 2 из 3 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 18, изображение 3 из 3
    • Carefully lift the orange flap using the black spudger. Then disconnect the cable from the motherboard.
  19. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 19, изображение 1 из 3 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 19, изображение 2 из 3 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 19, изображение 3 из 3
    • Using the tweezers, gently pull the cable off of the motherboard.
  20. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 20, изображение 1 из 2 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 20, изображение 2 из 2
    • Carefully lift the top portion of the motherboard off of the back panel with your hands.
  21. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 21, изображение 1 из 3 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 21, изображение 2 из 3 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 21, изображение 3 из 3
    • Using the tweezers, wiggle under the lower motherboard to remove adhesive.
    • Carefully grab the adhesives with the tweezers and lift up.
  22. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 22, изображение 1 из 2 Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 22, изображение 2 из 2
    • Gently lift up the lower motherboard.
    • Keep the two portions of the motherboard together. If the connecting cable is damaged, it could further ruin the condition of the board.
  23. Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement: шаг 23, изображение 1 из 1
    • Remove both pieces of the motherboard carefully from the back panel.
Заключение
9 участников успешно повторили данное руководство.
Nash Elder
Участник с: 04/18/18
761 Репутация
Автор 4 руководств
Команда
Cal Poly, Team S16-G5, Livingston Spring 2018 Участник Cal Poly, Team S16-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G5
5 членов
Автор 12 руководств
2 Комментариев
cool like it thanks for the help.
Hina - Ответить
Very understandable, thank you very much! From the Philippines!
Sthanlie Rayos - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 11
За последние 30 дней: 64
За всё время: 9,178
