Введение
Replacement of the motherboard requires removal of a few other components first. See the prerequisite guides before attempting just the motherboard.
Инструменты
Запчасти
Детали не указаны.
Heat the iOpeners in a microwave for 1-2 minutes.
Place heated iOpeners on screen edges to heat the adhesive.
Separate the screen assembly from the back by wedging the picks between the two components.
Slide the picks along the edge and leave them holding the device open all around the edges.
Place suctioning device near the corner of the screen and gently lift up to create a gap between the front panel assembly and the back.
Insert the picks to hold the two components apart once a gap is created.
Once all edges have been disconnected, carefully lift the screen off by pulling one side up.
Use the plastic opening tool to get under the connector piece. This will allow you to remove the front panel assembly from the rest of the device.
Detach the connecter from the inside of the device.
Lift the screen to separate the front panel assembly from the rest of the device.
Remove the 17 silver 3.0 mm Phillips head screws located around the edge of the device using the screwdriver.
Remove the 2 centrally-located black 3.0 mm Phillips head screws using the screwdriver.
Use the plastic opening tools to gently separate the middle panel from the rest of the device.
Move the tool around under the edges until you can remove the panel by hand.
Lift up the central panel starting from one corner to separate it from the rest of the device.
Pull towards the top of the device as you lift out to ensure that the charging port connection is not damaged.
Using the screwdriver, remove the 4 black 3.0 mm Phillips head screws located on the upper and lower motherboard.
Using the plastic opening tools unlock the 11 connectors that must be undone before the motherboard can be removed.
Using the plastic opening tool, continue disconnecting cables on upper motherboard.
Carefully lift the orange flap using the black spudger. Then disconnect the cable from the motherboard.
Carefully lift the top portion of the motherboard off of the back panel with your hands.
Using the tweezers, wiggle under the lower motherboard to remove adhesive.
Carefully grab the adhesives with the tweezers and lift up.
8 участников успешно повторили данное руководство.
Комментариев: 2
Very understandable, thank you very much! From the Philippines!
