Samsung Galaxy Tab S3 Front Facing Camera Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Tab S3 Front Facing Camera Replacement, Display: шаг 1, изображение 1 из 1
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Samsung Galaxy Tab S3 Front Facing Camera Replacement: шаг 2, изображение 1 из 1
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
  3. Samsung Galaxy Tab S3 Front Facing Camera Replacement: шаг 3, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Plastic Cards
    $2.99
    Купить
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
  4. Samsung Galaxy Tab S3 Front Facing Camera Replacement: шаг 4, изображение 1 из 3 Samsung Galaxy Tab S3 Front Facing Camera Replacement: шаг 4, изображение 2 из 3 Samsung Galaxy Tab S3 Front Facing Camera Replacement: шаг 4, изображение 3 из 3
    • Pull off the glass panel using the suction cup.
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  5. Samsung Galaxy Tab S3 Front Facing Camera Replacement, Rear glass panel: шаг 5, изображение 1 из 2 Samsung Galaxy Tab S3 Front Facing Camera Replacement, Rear glass panel: шаг 5, изображение 2 из 2
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
  6. Samsung Galaxy Tab S3 Front Facing Camera Replacement, Battery: шаг 6, изображение 1 из 2 Samsung Galaxy Tab S3 Front Facing Camera Replacement, Battery: шаг 6, изображение 2 из 2
    • Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
  7. Samsung Galaxy Tab S3 Front Facing Camera Replacement: шаг 7, изображение 1 из 1
    • The midframe should snap off from the device’s motherboard.
  8. Samsung Galaxy Tab S3 Front Facing Camera Replacement: шаг 8, изображение 1 из 3 Samsung Galaxy Tab S3 Front Facing Camera Replacement: шаг 8, изображение 2 из 3 Samsung Galaxy Tab S3 Front Facing Camera Replacement: шаг 8, изображение 3 из 3
    • Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
  9. Samsung Galaxy Tab S3 Front Facing Camera Replacement: шаг 9, изображение 1 из 2 Samsung Galaxy Tab S3 Front Facing Camera Replacement: шаг 9, изображение 2 из 2
    • Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
  10. Samsung Galaxy Tab S3 Front Facing Camera Replacement: шаг 10, изображение 1 из 2 Samsung Galaxy Tab S3 Front Facing Camera Replacement: шаг 10, изображение 2 из 2
    • Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
  11. Samsung Galaxy Tab S3 Front Facing Camera Replacement: шаг 11, изображение 1 из 1
    • The battery should now be removed and detached from the device.
  12. Samsung Galaxy Tab S3 Front Facing Camera Replacement, Front Facing Camera: шаг 12, изображение 1 из 3 Samsung Galaxy Tab S3 Front Facing Camera Replacement, Front Facing Camera: шаг 12, изображение 2 из 3 Samsung Galaxy Tab S3 Front Facing Camera Replacement, Front Facing Camera: шаг 12, изображение 3 из 3
    • Using a nylon spudger, carefully push the camera out of its framing.
    • Unlike the rear facing camera, you will be pushing this camera out from the front. Try to push on the side of the camera so as to not damage the lens with the pointy end of the spudger.
  13. Samsung Galaxy Tab S3 Front Facing Camera Replacement: шаг 13, изображение 1 из 2 Samsung Galaxy Tab S3 Front Facing Camera Replacement: шаг 13, изображение 2 из 2
    • Carefully pop the front facing camera off from the motherboard with the flat end of the spudger.
  14. Samsung Galaxy Tab S3 Front Facing Camera Replacement: шаг 14, изображение 1 из 1
    • Remove the front facing camera from the device.
Заключение
Еще один человек закончил это руководство.
Justin Ogihara
Участник с: 09/18/17
27 167 Репутация
Автор 52 руководств
Команда
EDU Team Участник EDU Team
Staff
7 членов
Автор 637 руководств
Один комментарий
This repair can be done without removing the screen!
hansderaedt - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 360
