Samsung Gear S3 Frontier Battery Replacement
Выберете то, что вам нужно
  1. Samsung Gear S3 Frontier Battery Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Place the watch screen-down so that its back cover is showing.
  2. Samsung Gear S3 Frontier Battery Replacement: шаг 2, изображение 1 из 2 Samsung Gear S3 Frontier Battery Replacement: шаг 2, изображение 2 из 2
    • Remove the four 4.2mm screws with a Y00 screwdriver.
    Y0 passte bei mir deutlich besser als Y00
    Alex Fi - Ответить
    Did you use iFixit tools? I just checked and I believe Y00 is correct. Y0 slips too easily. My test was with the Y bits from the Pro Tech Toolkit.
    Nicholas Dudde -
    I too had to use an Y0 screwdriver (from Ifixit 64 bit driver kit....). Y00 just don't grip, may be some batches of the watch used different screws??
    regislefeuvre - Ответить
    One screw just doesn't want to move, any suggestions/tips how to remove it?
    Slartibartfast - Ответить
    Problem solved: after 2 times of careful WD40 application and blunting the Y00 a bit it came of with a lot of patience.
    Slartibartfast -
    I also had a problem with one of the screws and flipping to Y0 worked for that one.
    Jeff Lambert - Ответить
    Yo use Y 0.6 y anduvo perfecto!!
    Gustavo Zarate - Ответить
    Yo use Y 0.6 y anduvo perfecto!!!
    The tool kit that came with my battery was a Y1.5 and worked perfectly
    jnewsom22 - Ответить
  3. Samsung Gear S3 Frontier Battery Replacement: шаг 3, изображение 1 из 3 Samsung Gear S3 Frontier Battery Replacement: шаг 3, изображение 2 из 3 Samsung Gear S3 Frontier Battery Replacement: шаг 3, изображение 3 из 3
    • This step will ruin the water-proof seal.
    • Wedge the metal spudger in between the back cover and the frame along the seam.
    • Use force to pry the back cover away from the main watch frame.
    • This step requires a lot of force. You can use a Jimmy in place of a metal spudger to make the process easier.
    Il est plus facile et moins domageable pour le joint de commencer par ouvrir le cache de connexion situé à coté de l’axe du bracelet long. On peut alors glisser la broche sans détériorer le joint, qui est plus éloigné du bord à cet endroit.
    Yann Richet - Ответить
    I’m pretty sure the seal is equally far away from the edge on all sides.
    Nicholas Dudde -
    This was the hardest part. I did use thin flat head screw to dismantle it. Using the metal spudger felt like impossible due to its thickness.
    Mariusz - Ответить
    Did using the screwdriver damage the case in any way? I’d recommend being careful using a tool with smaller surface area as that will apply more pressure at the point of entry. As the guide states, a Jimmy may also be used instead of the spudger.
    Nicholas Dudde -
    Anyone know where to buy the replacement gasket after breaking the seal between back cover and watch? Thanks.
    Jyon - Ответить
    Not sure if it's a gasket or some sort of sealant paste/gel. Just took my case off, and the gasket seems intact (fused to back cover of the watch. Quick search for waterproof sealant yielded lots of possibilities - don't know which one to choose. Can anyone with experience provide advice?
    Alan Lawee - Ответить
    most things I have seen online say use an RTV like permatex black sealant. pretty available at like autozone or o'reilly or walmart.
    Steven Betts -
    Ma questa guarnizione impermeabile si puo sostituire ? Come controllare se si è danneggiata? Come evitare che entri acqua dopo averlo aperto ?
    ant.beneduce - Ответить
    La photo montre une ouverture coté bouton mais pire coté car l'ouverture abime quand même le couvercle en plastique sur la face la plus visible : essayer plutôt sur les autres cotés
    stoufbook - Ответить
    Il est préférable d'utiliser, si possible, un outil adapté pour l'ouverture des boîtes de montre.
    Avec précaution, le joint n'est pas trop abîmé. Il est distendu. Possibilité de le couper et de le réajuster correctement.
    Fabrice - Ответить
    I have used a the Jimmy and I didn't need to do any force at all
    Carlos Rafael Ramirez - Ответить
    Que puedo usar para poner en la tapa y cambias el sellado ya que se me arruinó.
    Quiero que vuelva a ser hermético.
    Gracias
    damian levi - Ответить
  4. Samsung Gear S3 Frontier Battery Replacement, Front Screen Assembly: шаг 4, изображение 1 из 3 Samsung Gear S3 Frontier Battery Replacement, Front Screen Assembly: шаг 4, изображение 2 из 3 Samsung Gear S3 Frontier Battery Replacement, Front Screen Assembly: шаг 4, изображение 3 из 3
    • Detach the three connectors on the motherboard using your fingernail.
    • The connectors are easy to pop off. Minimal force is necessary.
  5. Samsung Gear S3 Frontier Battery Replacement: шаг 5, изображение 1 из 3 Samsung Gear S3 Frontier Battery Replacement: шаг 5, изображение 2 из 3 Samsung Gear S3 Frontier Battery Replacement: шаг 5, изображение 3 из 3
    • Separate the motherboard and front screen assembly using a spudger.
    Oui tuto bien clair. Opération réussi !
    Bien qu’adroit de mes mains, et après avoir découvert la “bête à coeur ouvert”, je ne sais pas si je me serais lancé... C’est tout l’interêt de ce Tuto qui invite à le faire (car pas trop de détails), et qui suivit pas à pas permet de s’en sortir. Bravo
    Merci Dan.S
    Dan.S - Ответить
    Better replace the 2 bolts from next step first.
    Gabriel Pinho - Ответить
    The guide has you remove the screws second because it makes it possible to remove the whole assembly without snapping any cables.
    Nicholas Dudde -
    Ok... Woher bekomme ich die Displayeinheit ???🤷🏻‍♂️
    Patrick Nufer - Ответить
  6. Samsung Gear S3 Frontier Battery Replacement, Battery: шаг 6, изображение 1 из 2 Samsung Gear S3 Frontier Battery Replacement, Battery: шаг 6, изображение 2 из 2
    • Using a JIS #00 screwdriver, remove the two 4.5 mm screws.
  7. Samsung Gear S3 Frontier Battery Replacement: шаг 7, изображение 1 из 3 Samsung Gear S3 Frontier Battery Replacement: шаг 7, изображение 2 из 3 Samsung Gear S3 Frontier Battery Replacement: шаг 7, изображение 3 из 3
    • Disconnect the battery ribbon cable from bracket.
    • Be careful with the battery ribbon cable and motherboard cable (located on the side opposite the battery cable, highlighted with the orange box), as they are very easy to break (ours did when disassembling).
    • Note how the end of the ribbon cable seats in the plastic chassis. Look for the plastic pin on the chassis when re-seating during re-assembly.
    • Separate the chassis from the motherboard.
    What happens if the battery ribbons breaks?
    sarah rus - Ответить
    Hi the ribbon has come away from the mother board. How do I stick it back on? What type of adhesive do I use?
    Peter Alderson -
    I broke my ribbon :( ordering a new one. How do I stick it on?
    Justin Lalonde -
    I also broke the ribbon for the motherboard. What adhesive should I use to reattach it
    danieljchoe - Ответить
    I'd like to know too please
    Justin Lalonde -
    Be very careful with a ribbon that cannot come off on the opposite side of the red box on the motherboard when preforming this step. I found this and managed to avoid it.
    Andrew Watson - Ответить
    You should first detach/separate the buttons ribbon cable from the side of the plastic casing so you don't tear/break it accidentally. (orange box, the cable is soldered onto the motherboard cannot detach it from there)
    István Szikra - Ответить
    I would advise not to do this like a guide said. Squirt some isopropyl between the pcb and battery to unglue it and carefully nudge it with a plastic spugger. Same with the adhesive that's holding the other end of the ribbon cable.
    Cryen - Ответить
  8. Samsung Gear S3 Frontier Battery Replacement: шаг 8, изображение 1 из 2 Samsung Gear S3 Frontier Battery Replacement: шаг 8, изображение 2 из 2
    • Separate the battery from the motherboard.
    • The battery and the motherboard are secured with adhesive; some force is needed.
    • Lithium-ion batteries are potentially dangerous. Handle with extreme care and do not puncture the battery.
    I just used this guide to do a replacement, the watch works perfect now. Pay attention to whats in your hand vs whats on the guide a couple of the steps are not as straightforward just take your time. Overall good guide though.
    Michael Carlson - Ответить
    Replaced the battery successfully with this guide. Take your time to carefully see whats on the watch compared to the guide.
    I removed the battery ribbon cable in step 7 by using a really small flat screwdriver to lift the cable from the housing. It's attached with adhesive tape.
    Eric Mulder - Ответить
    Perfect. I just remove the two bolts form step 6. Battery was a little difficult to remove due to a tape that attached it on board.
    Works very well.
    It took an extra tool that isn’t mentioned (very small, thin, straight screw driver), but it took only 20 minutes! Great step by step instructions!
    Walker - Ответить
    J'ai suivi tout le processus, au final la montre charge mais ne s'allume plus.
    liotard - Ответить
    Idem. Charge mais ne s'allume pas. On était pas obligé de séparer la carte mère du boîtier...
    Hug0o -
  9. Samsung Gear S3 Frontier Battery Replacement: шаг 9, изображение 1 из 2 Samsung Gear S3 Frontier Battery Replacement: шаг 9, изображение 2 из 2
    • When reassembling, place the battery into the plastic assembly first. Don’t stick it to the adhesive first. This way, it’s easy to position the battery cable.
    • When securing the battery cable, make sure the hole that the peg goes through is round. The hole on your replacement battery’s cable could be malformed. You may want to widen the hole before securing the cable.
    • To widen the hole, use the Pro Tech Toolkit’s SIM tool, a small paperclip or similar fine-tipped tool. The tool can also be used to gently press the battery cable into the correct position. Do this carefully to avoid damage.
    • Follow steps 8-1 in reverse order to reassmble.
    Notez que la montre ne redémarre pas tant que le boitier n’est pas fermé.
    Formidable demande de l'attention et de la délicatesse a solvé ma montre Frontière.
    Bravo et merci de partager.
    Alain ESCAFFRE chateauneuf le rouge FRANCE
    ESCAFFRE - Ответить
    Do you possibly have any suggestions on how to repair the battery cable ribbon once it becomes separated from the mother board?
    DC Cooper - Ответить
Заключение
139 человек успешно провели ремонт по этому руководству.
William Hurty
Участник с: 10/08/18
2 798 Репутация
Автор 3 руководств
Команду
Cal Poly, Team S15-G2, White Fall 2018 Участник Cal Poly, Team S15-G2, White Fall 2018
CPSU-WHITE-F18S15G2
4 членов
Автор 34 руководств
46Комментарии к руководству
Is there a way to reseal the watch making it water proof?
David R - Ответить
If the seal was damaged during opening the backcover, unfortunately you need a new backcover, cause the seal is integrated in the case.
Frank Mauderer -
where to buy the battery?
popoypoi22 - Ответить
https://www.amazon.com/Tesurty-Replaceme...
I bought mine from Amazon. Just replaced the battery after all the tool kit came in. It works like brand new!
Jae Shim -
is there a kit somewhere for the battery/new seal
Adam Seidlitz - Ответить
I bought mine here:
Battery: https://www.schreiber-electronics.de/sam...
Backcover with integrated seal: https://www.schreiber-electronics.de/sam...
Frank Mauderer -
The battery is part number EB-BR760ABE (as seen on picture in step 8). You can find it on Amazon and eBay.
did4 - Ответить
Most difficult part is getting that battery connector back in place. Otherwise, it’s a simple process. Just make sure to be careful with the connectors if you’re not used to playing with them.
hawleyst - Ответить
this guide is really well done my device works perfectly fine now and was super easy also I believe that there is a gasket and so you don't think have to buy a sealer
Landre Farrell - Ответить
i made the mistake of pulling the board too hard…The flex cable didnt break but it came lose from the board. Is there anyway to glue it back?
Kelvin Ventura - Ответить
You ever figure this out? Thanks
Honest News Network -
If you do not put the spudger in so deep as to damage the seal you do not need to replace it. Also, you do not need to remove the whole internals to replace the battery, if you disconnect the battery cable after removing the two #00 philips the battery and circuit board pivot open. Here is someone doing this same repair as I describe.
Brent Quick - Ответить
The battery in the photo shows the S/N but if your original battery # is Eb-br760, Eb-br760abe then you can find it at www.canadianbatteries.com
https://www.canadianbatteries.com/batter...
Dan Clark - Ответить
I need Gear s3 battery
Asmat khan - Ответить
I replaced the battery but when I put it on the charger it started flashing red, I read somewhere it means its unable to charge, any advice?
baculpojl - Ответить
Screwdriver didn't fix where can I find a 2mm screwdriver?
bowieinc - Ответить
I'm using the 64-bit driver kit from ifixit. The Y00 tri-tip bit doesn't grab the screw heads on the back of the watch casing. Is there another bit or driver kit that works better for this application? Note: I've tried the bits Y000 and Y0 and the pitch still doesn't grab properly.
Paxton Powers - Ответить
Can the Battery of the Galaxy Watch be used for the Gear S3?
Dzoni Filipovic - Ответить
After following these steps, the battery was replaced. The watch charges and reaches 100%, screen shows the percentage, but the watch will not power on. No cables were torn. Would you know what went wrong?
Jerry Castillo - Ответить
Mines doing the same thing. Did you ever figure it out. I went back in and made sure everything attached. Shows charged to 100% but won’t power on
Misty scheuerman -
I am also struggling with this. Power button no longer works after replacing battery.
Justin Lalonde -
Replaced battery but still only getting 24 hours (same as battery I replaced). Does it get better over time ?
Thanks in advance
Michael Humble - Ответить
I replaced my battery a few days ago, and it lasts (Theorically) about a one day and 22 hours, but it depends on how you use it. So I’m afraid that it won’t get better after a little time.
Anyway, Samsung website says this: “With the Gear S3, you can go for up to four days before putting it down for a charge. Its battery lasts that long.
*Battery life may vary depending on usage and settings.”
I don’t use it with the maximum performance and I still not getting those 4 days. If it changes for you, let us know!
I hope it gets better.
MemoryOverflow -
So I just replaced my battery in my S3 and so far is working just find. Charge is going up no issues so far.
Ricky's Journey - Ответить
What can i do if the ribbon cable in the corner becomes unattached? Is there a way to reattach? Thanks
Honest News Network - Ответить
I want authorized dealer to replace battery of my S3 gear watch and charge for job and battery at Jaipur
mr.omprakashsharma2006 - Ответить
Buon giorno, la batteria sono riuscito a cambiarla, nel riassemblaggio la batteria si carica ma nn si accende l l'orologio, ho provato a rismontarlo, ma a vedere così sembra tutto a posto, nn capisco cosa possa essere
Fabio DALL AGLIO - Ответить
Bonjour
après changement de ma batterie, à montre fonctionne en rechargement sur sa base mais l’écran reste éteind dès que je la prend en main..
y a t il quelque chose à faire?
nicomorizot - Ответить
Mine updated, and after updated the next time i charged it got hot…i noticed after this it would not accept charge anymore. Charger would just red blinking light after a few seconds. it took a few days and finally died for good, tried a friends charger but no good…I tried everything to make sure it wasn’t software…I think these watch batteries brick immediately if they ever get hot so that they won’t explode…I just wonder if replacing the battery would fix this for me?
RIPing PUMA - Ответить
I think samsung is a good company but at the time many other people complained of the same thing that after the update came battery problems…I wonder if samsung didnt test the update thoroughly enough and unintentionally destroyed a lot of watches?
RIPing PUMA -
this was a several months ago
RIPing PUMA -
Need help, I have a Galaxy Gear S3 Frontier model SM-765A. Been having problems with battery drain. I replaced the battery with a compatible EB-BR760ABE battery. Now when I charge it it the display reads (Can't Charge, Battery Needs To Warm Up). I have left it on for hours, still gives me the same result. Any suggestions.
Sal - Ответить
Mille Merci pour cette explication.
En moins de 10mn terminé ??
Bravoooo très bien expliqué
Greg neo - Ответить
I pulled out the mother board but the ribbon can off. Can it be placed back on?
Cantwell - Ответить
i changed the battery.  I fully charged it but it won't turn on
enver anursal - Ответить
I have the same issue
Justin Lalonde -
I replaced my battery but it will not turn on now. It charges but will not power on any suggestions?
Joseph Hill - Ответить
Same here. Watch won't power on after replacing and charging the new battery. It's like the power button no longer works
Justin Lalonde -
Samsung should be ashamed of the lack of support of this watch.
Allen Martin - Ответить
Hello all, i have a problem, 2 of the back cover screws cant be removed, is there a way to resolv this problem ?
Härūmi Stûdïõ - Ответить
Excellent tutorial, well done, requires patience, some time and some electronics knowledge, but it was SO helpful for me, and made the job less stressful and I knew it was done correctly, many thanks, Laurie - South Australia
Laurie Day - Ответить
I broke the motherboard cableI broke the motherboard cable😭.
Can anyone help me with this?Can anyone help me with this?
majed s - Ответить
After replacing my battery, I also noticed that my watch was much more responsive, before it had a noticable sluggishness and low framerate. Now it is much more snappy. I'm curious if Samsung made the watches throttle back to preserve the aging battery. Has anyone else noticed this?
John Hinton - Ответить
Bonjour,
J'ai remplacé la batterie mais ma montre ne se charge plus.
Une idée ?
Merci pour votre aide ! :)
Yves Roure - Ответить
I broke the ribbon to the mother board will the watch still work now?
tėe black - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 10
За последние 7 дней: 96
За последние 30 дней: 634
За всё время: 158,410
