Введение
This is a step by step guide to replacing your ram units in your laptop. Please ensure that your device is unplugged and completely powered down before attempting this repair.
Выберете то, что вам нужно
This guide should be attempted after the removal of the back panel is completed.
The Battery Removal guide demonstrates how to do this. The link to this guide is posed here. Samsung NP900X4B Battery Replacement
Locate the two sticks or DDR3 RAM. They can be found in the upper right-hand corner.
Use a plastic opening tool to nudge one clamp holding one stick of RAM outward. If done correctly the clamp should move away from the stick of RAM. Do this with the clamp on the opposite side of the same stick or RAM. The stick of RAM will pop up when both clamps are released
Repeat step 3 with the second stick of RAM. Again, when this is done correctly the RAM should pop up at an angle away from the laptop.
Еще один человек закончил это руководство.
