Введение
Screen replacement may need to be done when the screen is damaged, such as lines on the screen and not showing anything. Refer to the Troubleshooting page to see more information about this. This guide will display the steps needed to replace a damaged screen on Samsung RC512.
Выберете то, что вам нужно
Locate two notches above the battery.
Slide both battery locking notches to either side to remove the battery.
Pull the battery out.
Remove the gray covers with tweezers to expose the 4mm screws.
Using a Phillips #0 screwdriver, remove the four 4 mm Phillips #0 screws.
Insert the blue plastic opening tool into the bezel and rear housing of the screen.
Use the plastic opening tool to pop open the claps that hold the casing on the screen.
Work your way around the sides carefully and continue this to the bottom.
With the Phillips #0 screwdriver remove the six 3 mm screws, which mount the screen onto the base of the laptop.
Gently lay the LCD onto the keyboard.
Remove the tape that secures the video connector to the LCD screen with tweezers.
Grasp the video connector at its base and pull it away from the LCD screen.
Еще один человек закончил это руководство.
