Samsung RF28R7351 Fuse Block Module Replacement
Выберете то, что вам нужно
Видеообзор
  1. Samsung RF28R7351 Fuse Block Module Replacement, Fuse Box Module: шаг 1, изображение 1 из 1
    • Begin by disconnecting the power to the appliance
    • It is also recommended to test the outlet for the proper voltage
    • Also, turn off the water.
  2. Samsung RF28R7351 Fuse Block Module Replacement: шаг 2, изображение 1 из 1
    • You will need a Phillips screwdriver to remove the cover, which is held on by five Phillips screws.
    • Remove the five Phillips screws.
    • The lower middle screw is a machine screw thread, so keep it separate for reinstallation.
  3. Samsung RF28R7351 Fuse Block Module Replacement: шаг 4, изображение 1 из 2 Samsung RF28R7351 Fuse Block Module Replacement: шаг 4, изображение 2 из 2
    • With the panel removed, you now have clear access to the fuse block.
  4. Samsung RF28R7351 Fuse Block Module Replacement, Test continuity of fuses: шаг 5, изображение 1 из 2 Samsung RF28R7351 Fuse Block Module Replacement, Test continuity of fuses: шаг 5, изображение 2 из 2
    • The main reason why you'd be accessing your fuse block is if the unit has no power
    • Once the fuse block is removed, you can use your multimeter to test continuity on the metal sides of each one of these fuses.
    • (How to use a multimeter)
    • If one is blown, the fuse block will need to be replaced.
  5. Samsung RF28R7351 Fuse Block Module Replacement, Disconnecting the fuse block: шаг 6, изображение 1 из 2 Samsung RF28R7351 Fuse Block Module Replacement, Disconnecting the fuse block: шаг 6, изображение 2 из 2
  6. Samsung RF28R7351 Fuse Block Module Replacement, Installing a new fuse block: шаг 7, изображение 1 из 2 Samsung RF28R7351 Fuse Block Module Replacement, Installing a new fuse block: шаг 7, изображение 2 из 2
    • When installing your new fuse block, first install the wiring.
    • Make sure the connector is securely locked into place.
    • The red wire goes with the red, and the blue with the blue.
    • Swing it in at an angle and pop it in place.
  7. Samsung RF28R7351 Fuse Block Module Replacement, Reinstall the panel cover: шаг 8, изображение 1 из 1
    • Once the new fuse block is installed, you can reinstall the panel cover.
    • To reinstall your panel cover, first bring in the top at an angle and drop it on those hooks.
  8. Samsung RF28R7351 Fuse Block Module Replacement: шаг 9, изображение 1 из 3 Samsung RF28R7351 Fuse Block Module Replacement: шаг 9, изображение 2 из 3 Samsung RF28R7351 Fuse Block Module Replacement: шаг 9, изображение 3 из 3
Финишная прямая
eCuration
Участник с: 05/19/17
450 167 Репутация
Автор 252 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 22
За всё время: 544
