Введение
This guide shows how to remove and replace the door sensors in your Samsung refrigerator. If your refrigerator has only one door, you will have only one sensor.
The Samsung fridge uses a magnetic reed switch for each French door. If these sensors fail, the refrigerator will think a door is always open or closed.
This guide will work for most Samsung Refrigerators. This guide is based on a model RF28R7201SG Refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Выберете то, что вам нужно
Unplug your refrigerator before you begin your repair.
Condenser fan motor
Compressor motor and thermal overload device
Water supply valve assembly
Remove the screws securing the hinge cover (aka top table) on the top of the refrigerator.
Lift the edges of the hinge cover to loosen it from the refrigerator.
Flip the hinge cover over to access the cables underneath.
Use your fingers to release the wire connectors under the hinge cover.
Disconnect the wiring so you can remove the hinge cover.
The left door sensor
The left door sensor connector
The right door sensor
The right door sensor connector
Use your fingers to squeeze and disconnect the sensor cable connector.
Use a spudger or a flathead screwdriver to pry the sensor out of its retaining clips.
Repair didn’t go as planned? Ask our Answers Community for help.
Еще один человек закончил это руководство.
