Введение
This is a streamlined guide on how to replace Samsung WB150F Memory Card. There are no tools needed for this replacement. There are many parts at risk of being damaged, ensure that you follow the procedure with care. The time needed to complete this procedure is approximately 1 to 2 minutes.
Flip the camera upside-down so that the compartment with the battery and memory card is facing you.
Using your finger, slide the plastic lock-tab to the left.
The compartment should swing open.
2 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
Will a micro cd n an adapter fit n the camera?
I was looking for max size compatability. Most folks already know how to remove and install it.
