Введение
This guide for the Shark AI Ultra AV2511AE will show the steps for replacing the base filters. This will help if there are any problems with filtering and transferring trash from the smart vacuum to the base. It is also recommended to remove these filters and clean them every couple of months.
Remove the black cover on the post-filter located on the side of the base.
Pull the "DOWN" tab and remove the filter.
Open the white cover on the pre-filter located on the top of the base.
Remove the filter.
