Shower Arm Replacement
Выберете то, что вам нужно
  1. Shower Arm Replacement, Shower Arm: шаг 1, изображение 1 из 3 Shower Arm Replacement, Shower Arm: шаг 1, изображение 2 из 3 Shower Arm Replacement, Shower Arm: шаг 1, изображение 3 из 3
    • Turn off the main water supply. Turn the wheel clockwise (right) to shut off water (if there is 2 wheels, turn both of them clockwise). Turn it until it stops — do not force it.
    • If the valve has a lever handle, rotate it 90° so it is perpendicular to the pipe.
    • In a house, the main shutoff valve is typically located in the basement, near the water meter, or where the main water line enters the home. In a condo, the shutoff may be inside a utility closet, mechanical panel, or bathroom access panel. If unsure, contact building management.
  2. Shower Arm Replacement: шаг 2, изображение 1 из 3 Shower Arm Replacement: шаг 2, изображение 2 из 3 Shower Arm Replacement: шаг 2, изображение 3 из 3
    • Use an adjustable wrench to loosen the nut that connects the shower head to the shower arm.
    • Turn the nut counterclockwise until the shower head comes off.
  3. Shower Arm Replacement: шаг 3, изображение 1 из 1
    • Gently slide the decorative flange (the round metal cover) away from the wall.
    • This exposes the threaded connection where the shower arm enters the wall.
  4. Shower Arm Replacement: шаг 4, изображение 1 из 1
    • Grip the shower arm with a wrench covered with a cloth or rag to protect the finish and turn it counterclockwise. Continue turning until the shower arm fully unscrews from the wall fitting.
    • Use a cloth or rag between the wrench and the shower arm to prevent scratching the finish.
  5. Shower Arm Replacement: шаг 5, изображение 1 из 1
    • Use a cloth or a rag to remove old plumber’s tape residue or debris from the threaded fitting inside the wall.
  6. Shower Arm Replacement: шаг 6, изображение 1 из 1
    • Wrap plumber’s tape clockwise 2–4 times around the threaded end of the new shower arm.
  7. Shower Arm Replacement: шаг 7, изображение 1 из 3 Shower Arm Replacement: шаг 7, изображение 2 из 3 Shower Arm Replacement: шаг 7, изображение 3 из 3
    • Screw the new shower arm clockwise into the wall fitting until it is securely installed.
    • Slide the decorative flange back against the wall.
  8. Shower Arm Replacement: шаг 8, изображение 1 из 2 Shower Arm Replacement: шаг 8, изображение 2 из 2
    • Reattach the showerhead and use an adjustable wrench to turn the nut clockwise to secure it to the shower arm.
  9. Shower Arm Replacement: шаг 9, изображение 1 из 1
    • Turn the water supply back on and test the shower for leaks around the connection.
Заключение
After installing the new shower arm and reconnecting the shower head, turn the main water supply back on and test the shower for leaks. If you notice any dripping around the connection, tighten the fittings slightly or apply additional plumber’s tape. Once the connections are secure, your shower arm replacement is complete.
Еще один человек закончил это руководство.
Tim
Участник с: 01/20/26
193 Репутация
1 руководство автора
Команда
York University, Team 1-9, Woodhouse Winter 2026 Участник York University, Team 1-9, Woodhouse Winter 2026
YORK-WOODHOUSE-W26S1G9
2 членов
Автор 1 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 33
За всё время: 138
