Shower Handle O-ring Replacement
Выберете то, что вам нужно
  1. Shower Handle O-ring  Replacement, Shower Handle O-ring: шаг 1, изображение 1 из 1
    • Be sure your water main is turned off, preventing water flow to your shower.
    • Using your flat head screwdriver, remove the screw from the middle of the handle.
  2. Shower Handle O-ring  Replacement: шаг 2, изображение 1 из 1
    • Use your groove joint pliers to loosen and remove the escutcheon plate.
  3. Shower Handle O-ring  Replacement: шаг 3, изображение 1 из 1
    • Using your groove joint pliers, loosen and remove the cartridge stem.
  4. Shower Handle O-ring  Replacement: шаг 4, изображение 1 из 1
    • Slowly unscrew and remove the stem completely.
    • There may be some water leakage due to built up pressure.
  5. Shower Handle O-ring  Replacement: шаг 5, изображение 1 из 2 Shower Handle O-ring  Replacement: шаг 5, изображение 2 из 2
    • Using your flat head screwdriver, remove the screw from the end of the stem cartridge.
    • Once the screw is removed, replace the damaged O-ring with the new replacement O-ring.
    • When installing a new O-ring, be sure the O-ring has a tight seal to prevent further leaking.
    • Once reassembly is complete and all parts are snug, turn the water main back on to allow water to flow to the shower again.
Финишная прямая
3 человек успешно провели ремонт по этому руководству.
Cori Fitzpatrick
Участник с: 03/20/16
213 Репутация
1 руководство автора
Команда
Michigan Tech, Team 1-6, Lauer Spring 2016 Участник Michigan Tech, Team 1-6, Lauer Spring 2016
MTU-LAUER-S16S1G6
1 член
Автор 1 руководств
4 Комментарии к руководству
This fixed the dripping shower head but now my shower handles are tight and difficult to turn and the water pressure is affected after replacing the o-rings. What could the issue be?
Cin - Ответить Поделиться
Try putting petroleum jelly all over the outside of the stem/cartridge (including the threading/grooves) before screwing it all back together. That will keep your handles turning smoothly, and easily.
It's the plumbing equivalent to WD40.
Jess - Ответить Поделиться
As for the change in water pressure, I'm not sure what that would be. Did you use the same size O-ring?
I have the same handles and stems, but leaking not from the rubber. Leaking occuring when tuning on the handle. Do you know where to find the parts?
Phil Yue - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 10
За последние 7 дней: 47
За последние 30 дней: 195
За всё время: 25,975
