Shure SM58 XLR Connector Wire Repair
Выберете то, что вам нужно
  1. Shure SM58 XLR Connector Wire Repair, XLR Microphone Connector Disassembly: шаг 1, изображение 1 из 1
    • Using a small flat head screwdriver, gently turn the retaining screw at the bottom of the microphone counterclockwise until it stops or provides resistance.
    • The retaining screw is mounted to the connector and has a left-handed thread. Turning the screw clockwise locks the connector in place. Turning it counterclockwise lowers it down into the hole, releasing the connector.
    • Once the screw stops, do not try to loosen it further.
  2. Shure SM58 XLR Connector Wire Repair: шаг 2, изображение 1 из 1
    • Plug an XLR cable into the loose connector.
    • While holding the disconnect button down, pull on the cable to remove the connector from the body of the microphone.
  3. Shure SM58 XLR Connector Wire Repair, Shure SM58 XLR Connector Wire Repair: шаг 3, изображение 1 из 1
    • If the wire is not exposed from the insulation, strip the broken wire.
  4. Shure SM58 XLR Connector Wire Repair: шаг 4, изображение 1 из 1
    • Bend the wire around the contact point. Pin numbers are located on the outside of the connector.
    • Connect the red wire to Pin 3 and the blue wire to Pin 2.
    • Pin 1 should have a single piece of exposed wire connecting it to the metal plate on the top of the connector (the ground plate).
  5. Shure SM58 XLR Connector Wire Repair: шаг 5, изображение 1 из 1
    • Clamps are helpful for this step.
    • In one hand, hold the solder. In the other, hold your soldering iron.
    • Touch both the soldering iron and the solder to the contact point. The solder should melt and create a connection between the wire and the microphone connector.
  6. Shure SM58 XLR Connector Wire Repair: шаг 6, изображение 1 из 1
    • Remove the solder and then the soldering iron from the contact point.
    • If you remove the soldering iron first, the solder may become stuck to the contact point.
    • Let the wire cool for 30 seconds or so.
    • If the wire is not completely connected repeat steps 2 through 5.
  7. Shure SM58 XLR Connector Wire Repair: шаг 7, изображение 1 из 1
Заключение
After soldering the wires to the XLR connector and reassembling your microphone, your microphone should be ready to plug in to the XLR cable and function properly.
4 человек успешно провели ремонт по этому руководству.
nat coll
Участник с: 09/27/12
733 Репутация
Автор 14 руководств
Команду
Cal Poly, Team 7-53, Forte Fall 2012 Участник Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 членов
Автор 30 руководств
9Комментарии к руководству
Many thanks. Very helpful.
Namron - Ответить
Yes I'm glad it was so simple and quick to fix my mic!
heyaly - Ответить
Red wire to pin 3? Seems to go against the pin 2 hot method?
Jim - Ответить
I'm not familiar with the "pin 2 hot method." We took a working mic apart and reassembled it the way we found it, so I'm pretty that is the correct soldering configuration.
Daniel Berger -
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 4
За последние 7 дней: 18
За последние 30 дней: 103
За всё время: 30,361
