Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Insert bolt hardware through the factory drilled holes from the top side of the skateboard.
If you have a riser and would like to install it, please reference the Wheel Bite Prevention guide.
Slide the truck onto the four protruding bolt hardware screws, while using your hand to prevent the screws from popping out the top of the skateboard.
While holding the nuts on the bottom side of the skateboard in place with the 3/8" wrench, tighten the screws from the top side of the skateboard with a screwdriver. Tighten the screws in a diagonal pattern until the head of the screw sinks slightly into the grip tape.
Repeat steps 1 - 6 to install the second truck.
2 участников успешно повторили данное руководство.
