Skullcandy Crusher Wireless Headphone USB Connector Replacement
Выберете то, что вам нужно
  1. Skullcandy Crusher Wireless Headphone USB Connector Replacement, Ear Cushion: шаг 1, изображение 1 из 2 Skullcandy Crusher Wireless Headphone USB Connector Replacement, Ear Cushion: шаг 1, изображение 2 из 2
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Headphone USB Connector Replacement: шаг 2, изображение 1 из 2 Skullcandy Crusher Wireless Headphone USB Connector Replacement: шаг 2, изображение 2 из 2
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Headphone USB Connector Replacement: шаг 3, изображение 1 из 1
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Headphone USB Connector Replacement, USB Connector: шаг 4, изображение 1 из 2 Skullcandy Crusher Wireless Headphone USB Connector Replacement, USB Connector: шаг 4, изображение 2 из 2
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion.
  5. Skullcandy Crusher Wireless Headphone USB Connector Replacement: шаг 5, изображение 1 из 3 Skullcandy Crusher Wireless Headphone USB Connector Replacement: шаг 5, изображение 2 из 3 Skullcandy Crusher Wireless Headphone USB Connector Replacement: шаг 5, изображение 3 из 3
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Headphone USB Connector Replacement: шаг 6, изображение 1 из 2 Skullcandy Crusher Wireless Headphone USB Connector Replacement: шаг 6, изображение 2 из 2
    • Separate the headphone speaker assembly from headphone speaker frame.
  7. Skullcandy Crusher Wireless Headphone USB Connector Replacement: шаг 7, изображение 1 из 1
    • Inspect the USB port and ensure that it is connected correctly. If necessary, desolder the USB port and replace it with the new port.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
Заключение
Val
Участник с: 03/31/22
1 080 Репутация
Автор 6 руководств
Команда
UMass Dartmouth, Team 1-33, Gurgel Spring 2022 Участник UMass Dartmouth, Team 1-33, Gurgel Spring 2022
UMASSD-GURGEL-S22S1G33
1 член
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 13
За последние 30 дней: 40
За всё время: 954
