Skytex SP728 Battery Replacement
Выберете то, что вам нужно
  1. Skytex SP728 Battery  Replacement, Case: шаг 1, изображение 1 из 1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Battery  Replacement: шаг 2, изображение 1 из 1
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Battery  Replacement: шаг 3, изображение 1 из 1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Battery  Replacement: шаг 4, изображение 1 из 1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Battery  Replacement, Battery: шаг 5, изображение 1 из 1
    • Remove the yellow and black tape around the battery very carefully
  6. Skytex SP728 Battery  Replacement: шаг 6, изображение 1 из 2 Skytex SP728 Battery  Replacement: шаг 6, изображение 2 из 2
    • Use the soldering iron and remove soldered connections to separate the wires connected to the battery from the circuit board.
    • Follow the link below for additional soldering information How To Solder and Desolder Connections
    • Soldering uses heat so make sure you are careful while doing it. Also, excessive heat can damage the components. So do not apply the soldering iron on a component for extended periods of time.
  7. Skytex SP728 Battery  Replacement: шаг 7, изображение 1 из 1
    • Using the plastic opening tool, lift up the battery from right edge and set aside.
    • Make sure that you take the battery out very carefully without bending it or damaging it as it contains toxic chemicals.
    • While soldering the wires for the new battery, remember that the red wire has to be connected to the positive terminal and the black wire has to be connected to the negative terminal.
Заключение
To reassemble your device with a new battery, follow these instructions in reverse order.
Еще один человек закончил это руководство.
Galika Adhikari
Участник с: 01/21/15
248 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 5-1, Brown Winter 2015 Участник USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 членов
Автор 11 руководств
Один комментарий
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 9
За всё время: 741
