Введение
By following this guide one is able to access the antenna of the Skypad Skytex Alpha 2 tablet in two steps. These steps include removing any metallic tape that holds the antenna and removing soldered connections.
Выберете то, что вам нужно
Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
Remove the metallic electrical tape, just enough, to allow the antenna to hang freely.
Remove the soldered connections to separate the antenna wire from the motherboard.
