Введение
By following this guide one is able to access and remove the battery of the Skytex Skypad Alpha 2 tablet in two steps. These steps include removing soldered connections and the removing of the battery itself.
Выберете то, что вам нужно
Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
Remove soldered connections to separate the battery wires from the motherboard.
Еще один человек закончил это руководство.
Один комментарий
Excellent Guide
Problem is where to obtain the Replacement battery ???
