Skytex Skypad Alpha 2 Speaker Replacement
Выберете то, что вам нужно
  1. Skytex Skypad Alpha 2 Speaker Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Power off the tablet.
    • Unplug the tablet from the power source if it is connected.
  2. Skytex Skypad Alpha 2 Speaker Replacement: шаг 2, изображение 1 из 2 Skytex Skypad Alpha 2 Speaker Replacement: шаг 2, изображение 2 из 2
    • Remove the (4) 3.5mm screws using a phillips #000 screwdriver.
  3. Skytex Skypad Alpha 2 Speaker Replacement: шаг 3, изображение 1 из 1
    • Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
  4. Skytex Skypad Alpha 2 Speaker Replacement: шаг 4, изображение 1 из 1
    • Release the back case from the rest of the tablet with your hand.
    • Do not pry the case too hard; doing so can damage the tablet.
  5. Skytex Skypad Alpha 2 Speaker Replacement, Speaker: шаг 5, изображение 1 из 1
    • Remove the soldered connections to separate the speaker wires from the motherboard.
    • Remove all black and yellow tape, if necessary, on the motherboard.
    • Following the red and black wires, coming out of the speaker, to their respective connections on the motherboard will indicate where to solder.
    • Follow the link below for further soldering information: How To Solder and Desolder Connections.
    • Soldering irons require a larger amount of heat; use caution when performing this step. Excessive heat can damage parts of your device; do not leave the soldering iron on connections for extended periods of time.
  6. Skytex Skypad Alpha 2 Speaker Replacement: шаг 6, изображение 1 из 1
    • Remove the speaker from the tablet using the plastic opening tool.
    • This will not require much force, prying from the flat side of the speaker will do the job.
Заключение
Еще один человек закончил это руководство.
Rebecca Ramirez
Участник с: 09/23/15
481 Репутация
Автор 3 руководств
Команда
Baylor, Team 6-5, Williams Fall 2015 Участник Baylor, Team 6-5, Williams Fall 2015
BU-WILLIAMS-F15S6G5
3 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 122
