Введение
This guide will demonstrate how to replace the fuse located in the cigarette lighter power source.
Выберете то, что вам нужно
Unscrew the small black screw at the base of the cigarette lighter power source.
Carefully unwind the cord at the base of the power source from the plastic case.
5 человек успешно провели ремонт по этому руководству.
18 Комментарии к руководству
I lost the tip that screws onto the end of the plug in and the 15 amp fuse. Can I get a replacement tip for it?
Can I get a replacement tip and ew 15 amp fuse
I lost the tip that screws onto the end of the plug in and the 15 amp fuse. Can I get a replacement tip and 15 amp fuse for it. This is for model 40051.
I somehow lost the tip of the plug-in, the part the screws on/off to keep the 15 Amp fuse inside.
Can I get a replacement piece or do I have to buy a new one?
Can someone please answer this??? I didn’t lose mine but the tip melted and now I can’t use my pump at all and I can’t find replacements for it anywhere:((
