Solio CLASSIC2 Electric Wire Replacement
Выберете то, что вам нужно
  1. Solio CLASSIC2 Electric Wire Replacement, Disconnecting the Battery: шаг 1, изображение 1 из 1
    • Turn off the device by pressing on the clear power button behind the device.
    • To make sure that it is off, make sure the button is not flashing green.
  2. Solio CLASSIC2 Electric Wire Replacement: шаг 2, изображение 1 из 1
    • Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
  3. Solio CLASSIC2 Electric Wire Replacement: шаг 3, изображение 1 из 3 Solio CLASSIC2 Electric Wire Replacement: шаг 3, изображение 2 из 3 Solio CLASSIC2 Electric Wire Replacement: шаг 3, изображение 3 из 3
    • Using the plastic opening tools, gently pry open the side of the large panel.
    • Keeping the tool in, slowly slide the tool along the side of the panel.
  4. Solio CLASSIC2 Electric Wire Replacement: шаг 4, изображение 1 из 2 Solio CLASSIC2 Electric Wire Replacement: шаг 4, изображение 2 из 2
    • Rotate the device 180 degrees.
    • Make sure the opening on other side of the device does not snap closed.
    • Gently slide the plastic opening tool along the side of the panel.
  5. Solio CLASSIC2 Electric Wire Replacement: шаг 5, изображение 1 из 2 Solio CLASSIC2 Electric Wire Replacement: шаг 5, изображение 2 из 2
    • Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel.
    • Using both hands, slowly pull apart the back panel from the rest of the device.
    • Gently flip the back panel open so the circuit board faces up and the two panels are side by side.
  6. Solio CLASSIC2 Electric Wire Replacement: шаг 6, изображение 1 из 2 Solio CLASSIC2 Electric Wire Replacement: шаг 6, изображение 2 из 2
    • Softly pinch the red and blue wires close to the white connector.
    • To pull the wires out, wiggle them back and forth until the connector is fully out.
  7. Solio CLASSIC2 Electric Wire Replacement, Circuit Board: шаг 7, изображение 1 из 1
    • Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
  8. Solio CLASSIC2 Electric Wire Replacement: шаг 8, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
    • Gently lift the circuit board out of the device using tweezers.
  9. Solio CLASSIC2 Electric Wire Replacement, Electric Wire: шаг 9, изображение 1 из 2 Solio CLASSIC2 Electric Wire Replacement, Electric Wire: шаг 9, изображение 2 из 2
    • Soldering can melt key components and cause harm to both the user and the device. Read soldering guide before attempting.
    • Using a solder iron with a fine tip, slowly solder off the broken wire from the first connection point.
    • Repeat for other connection point of wire.
Заключение
Kelly Perkins
Участник с: 10/20/13
110 Репутация
1 руководство автора
Команда
Cal Poly, Team 4-28, Amido Fall 2013 Участник Cal Poly, Team 4-28, Amido Fall 2013
CPSU-AMIDO-F13S4G28
4 членов
Автор 7 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 13
За всё время: 428
