Введение
If your Sony a6000 camera's flash so happens to not be working properly first check and make sure if there are no issues with the battery that is in the camera. Also try checking if the flash is on and not on auto or off. If you have checked all these possible issues and your flash is still faulty then this helpful step-by-step guide on how to successfully repair or replace the flash on the Sony a6000 camera will restore your camera's flash to where you can take all the pictures you want with a like new operating flash.
Выберете то, что вам нужно
Position the camera with the flash assembly facing upwards.
Locate the flash assembly.
Open the flash assembly.
Using the Phillips #00 screwdriver, remove the single screw beneath the flash assembly.
Position the camera with the LCD screen facing upwards.
Pull back the LCD Screen.
Using the Phillips #00 screwdriver, remove the three screws beneath the viewfinder.
To remove the top panel it is not necessary to remove the screw right of the eye guard.
Position the camera with the HDMI port facing upwards.
Using the Phillips #00 screwdriver, unscrew the single screw on the left side of the camera body.
To remove the top panel, another 2 screws under the battery (battery panel) must be removed, too.
Position the camera with the top panel facing upwards.
Carefully separate the top of the camera from the body using plastic opening tool.
Position the camera so the top panel's underside is facing you
Using the Phillips #00 screwdriver, unscrew the screw underneath the flash assembly.
Carefully remove the flash assembly from the top pannel
Just pull the flash connector to remove the flash assemby. A toothpick can be helpful, especially to later reconnect the cable.
4 человек успешно провели ремонт по этому руководству.
5Комментарии к руководству
Anyone know where to get the flash? My daughter’s has the “won’t stay closed” problem so common to the a-series and I need to replace it.
Thanks, good guide but please update it according to Jürgens comments or there is a big risk people will break their top panel.
David: I got the flash unit from AliExpress, but you can find it on Ebay as well.
Thanks for the guide! I had to open additional 2 more screws inside the battery compartment. and only had to remove 2 bottom screws on Step 8 (instead of 3). Replaced the flash unit without any issue. Thank you!
Thank you for the Description, for me I had 2 screws below the view finder, and also 2 in the battery compartment that needed to come loose.
I did not have any screws behind the button to adjust for your eye sight.
I did have some issues to get the cable back in properly, and had to tape my metal tweezer not to get zapped over and over again.
What worked best for me was a flat tweezer and gently push it in.
When Placing back the top panel i had some issues with the alignment with the on off button as initially i couldn't turn the camera on/off any more. After trying some positions with the on off button it worked.
