Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Disassembling the back cover of the camera so that we can repair components from the inside.
Выберете то, что вам нужно
Slide the battery cover in the direction the arrow points.
Pull the battery cover towards you.
Flick the blue switch for the battery to pop out.
Remove the battery from the camera.
Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
Remove that panel.
Remove the screw with a Phillips #00 Screwdriver from the right side of the camera (with '3x optical zoom' engraved on the side panel).
Remove that panel.
Remove the screw using the Phillips #00 Screwdriver from the bottom the camera, closest to the back cover.
2 участников успешно повторили данное руководство.
