Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If the device is having trouble reading disks, the laser may need to be replaced.
Выберете то, что вам нужно
Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
Punch through the warranty sticker with the spudger.
Remove the screw underneath with the Phillips screwdriver.
Remove the rubber feet using the spudger.
Remove the screws that were covered by the rubber feet.
Be careful when removing the rods because a fragile metal piece may break.
Pull laser off of the rods.
