Введение
This guide provides instruction for installing a motherboard for the Sony Ericsson TM506 cell phone.
Выберете то, что вам нужно
Firmly hold the phone between your fingers with your thumb on the battery cover.
Push down with your thumb until the battery cover comes off.
Remove the two rubber casings for the top two screws with a plastic opening tool.
There are eight snap hooks located around the outer case. Carefully snap these to remove the outer case.
The sound box is attached to the case by two snap hooks.
Lift the sound box up to remove it from the case.
Locate the 80-pin connector.
Carefully, lift up on the connector to separate it from the board.
There are two snap hooks that attach the motherboard to the case.
Using a plastic opening tool, carefully lift up on the motherboard to detach it.
