Sony FDL-220R Watchman Battery and Battery Contacts Replacement
Выберете то, что вам нужно
  1. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove battery cover and batteries: шаг 1, изображение 1 из 2 Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove battery cover and batteries: шаг 1, изображение 2 из 2
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Inspect battery contacts in battery compartment: шаг 2, изображение 1 из 1
    • Inspect battery contacts for any signs of damage.
    • Clean battery contacts with a solution of warm water and baking soda if there is corrosion.
  3. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove screws: шаг 3, изображение 1 из 2 Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove screws: шаг 3, изображение 2 из 2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  4. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove back casing: шаг 4, изображение 1 из 2 Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove back casing: шаг 4, изображение 2 из 2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  5. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Inspect battery contacts on inside of back cover: шаг 5, изображение 1 из 1
    • Inspect the two small springs on the back of the battery compartment.
    • Clean contacts with a solution of warm water and baking soda if there is corrosion.
Заключение
Sam Putnam
Участник с: 10/22/14
484 Репутация
Автор 4 руководств
Команда
Baylor, Team 4-5, Williams Fall 2014 Участник Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 13
За всё время: 497
