Sony RM-LVR1 Motherboard Replacement
Выберете то, что вам нужно
  1. Sony RM-LVR1 Motherboard Replacement, Battery: шаг 1, изображение 1 из 1
    • Use a Phillips #00 screwdriver to remove the four (4) screws on the back of the device.
    • If the screws strips or is previously stripped, refer to the stripped screw repair guide.
  2. Sony RM-LVR1 Motherboard Replacement: шаг 2, изображение 1 из 1
    • Battery is the rectangular and silver object in the center of device.
    • Remove battery with finger by prying at the rear.
    • If unable to remove battery, pry out using spudger.
  3. Sony RM-LVR1 Motherboard Replacement, LCD Screen: шаг 3, изображение 1 из 2 Sony RM-LVR1 Motherboard Replacement, LCD Screen: шаг 3, изображение 2 из 2
    • Unscrew the 3 (three) screws holding the bracket in place.
    • Then remove the bracket by prying one end up.
    • Do not rip the ribbon cable connecting the bracket to the motherboard.
  4. Sony RM-LVR1 Motherboard Replacement: шаг 4, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Купить
    • With tweezers, unplug the ribbon cable from the white connector.
  5. Sony RM-LVR1 Motherboard Replacement: шаг 5, изображение 1 из 1
    • Remove motherboard from the device by pulling upward gently, with fingers or tweezers.
  6. Sony RM-LVR1 Motherboard Replacement: шаг 6, изображение 1 из 1
    • Gently push out on these two clips holding the LCD to the motherboard
    • Once you have the first two off, ever so carefully, push the LCD towards the remaining two clips.
    • There is a ribbon cable underneath the LCD connecting it to the motherboard. Avoid sharp, sudden movements to prevent it from being damged
  7. Sony RM-LVR1 Motherboard Replacement: шаг 7, изображение 1 из 2 Sony RM-LVR1 Motherboard Replacement: шаг 7, изображение 2 из 2
    • Undo the ribbon cable attached between the motherboard and screen by prying up black tab which holds the cable, using spudger. (See pictures)
  8. Sony RM-LVR1 Motherboard Replacement: шаг 8, изображение 1 из 1
    • Remove the screen from the motherboard.
Заключение
Еще один человек закончил это руководство.
Alexander Thomas
Участник с: 09/28/17
265 Репутация
Автор 2 руководств
Команда
Eastern Washington University, Team S2-G2, Crane Fall 2017 Участник Eastern Washington University, Team S2-G2, Crane Fall 2017
EWU-CRANE-F17S2G2
3 членов
Автор 6 руководств
Один комментарий
Hello
Thank you for your tutorial.
My question is about the rubber cap of the push button
Can it be changed? Spare part ?
Regards
gilbert keiser - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 10
За всё время: 275
