Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If for any reason the floppy drive isn't working, the simplest solution is to replace the entire drive. But, if you're not able to aquire a new drive you may be able at least find the source of the failure through disassebling the drive.
Выберете то, что вам нужно
Turn the copmuter over so that its underside is facing up. Then slide the blue floppy drive release button down and pull the floppy drive out of the laptop.
There are two screws on each side (total of four screws) of the floppy drive. Remove these screws.
Once you have removed the screws, you can remove the floppy drive core from its casing as shown.
After you have removed the floppy drive core from its casing, unscrew these five screws shown.
Now that the screws are removed, you can remove the entire processing unit of the floppy drive.
Here is an isolated image of the core hardware of the floppy drive. Here is where the floppy "magic" happens. Check for any connection failures or shortages. You may need to re solder some of the connections.
