Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Removing this part is hard for the first time because the manufacturer used adhesive to keep it in place.
Выберете то, что вам нужно
Use the plastic opening tool to pry the top plastic section off.
Use the plastic opening tool to pry the bottom plastic section off.
Remove the four 5mm screws.
Use the plastic opening tool to pry off the back.
Use the plastic opening tool to detach the ribbon running across the battery.
Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
4 участников успешно повторили данное руководство.
